 Post subject: WD Scorpio WD3200BEVT strange read errors
PostPosted: June 21st, 2012, 6:50
Hi I am having some trouble imaging this drive;
Western Digital Scorpio
WD3200BEVT
320GB
The imaging process starts off ok but then stops and the drive seems unreadable. If i skip 200k sectors and start again it works for a while, then stops reading.
Basically it seems to fail in a pattern.
0 - 550000 readable
550001 - 750000 unreadable
750001 - 1303000 readable
1303001 - 1503000 unreadable
1503001 - 2063000 readable
Approx 550k is readable at a time followed by approx 200k unreadable.
Any ideas what could be causing it, or suggestions on how to image the drive? I suspect a head failure or maybe a scratch but would either of those produce what seems like a pretty regular pattern...
Any advice would be greatly appreciated.
 Post subject: Re: WD Scorpio WD3200BEVT strange read errors
PostPosted: June 21st, 2012, 7:05
Seems like a head issue. What image tool do you use?
PostPosted: June 21st, 2012, 8:29
Hi thanks for the reply. I suspect that it is the head too, is there a way I can confirm it?
I have been trying it with dd in Linux.
PostPosted: June 21st, 2012, 9:13
hi
you'll need an imager able to make a headmap and check if 1 head is related to all those LBAs.
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: June 21st, 2012, 10:48
irs wrote:
hi
Bye
Luca
Thanks I will look for something that can do that, any recommendations? preferably free :)
PostPosted: June 21st, 2012, 11:08
samtone wrote:
irs wrote:
hi
Bye
Luca
The type of hardware imagers irs is referring to are Deepspar DDI & Atola but your looking at about £2,500 - £3,000 min.
Sorry to tell you but you are not going to get a free fix.
If head 1 turns out to be faulty then your out of luck with DIY.
Will send you a PM if you want me to take a look? I'm near Derby & am not to far from Birmingham
Loki
PostPosted: June 21st, 2012, 11:55
loki wrote:
samtone wrote:
irs wrote:
hi
Bye
Luca
Loki
Hi Loki, thanks for the offer.
The data, although sentimental, isn't really worth sending for pro recovery. I am a bit of a tinkerer so if there is anything I can at minimal expense I will give it a try.
Out of curiosity, is it possible to connect the terminal pins with a rs232/ttl adaptor and test the heads that way? Is that what Deepspar /Atola do?
PostPosted: June 21st, 2012, 12:16
in these drives you don't have a diagnostic consolle via com port as for seagate drives.
so you can't use DIY solution through TTL.
Deepspar and Atola (pc3000 DE and SD datacompass also ;) )make a map of the LBA for each head and that way you can skip the surface for the broken head.
Bye
Luca
Users browsing this forum: Doomer, unknown and 42 guests
