 Post subject: Seagate 100536501 REV A LED CC Short Pin Location?
PostPosted: June 30th, 2012, 11:52
Hi
Does anyone happen to have an image of the short location on above board for LED CC Short procedure?
Scott
 Post subject: Re: Seagate 100536501 REV A LED CC Short Pin Location?
PostPosted: June 30th, 2012, 15:41
Can you post a pic of both sides of the board?
PostPosted: June 30th, 2012, 16:49
What kind of procedure do you mean?
PostPosted: July 1st, 2012, 7:45
Pictures of PCB attached
The procedure was recommended by pc3000 support staff when terminal access is blocked.
Here is message sent to PC3000 support staff:
I have a Seagate drive as per above with the following symptoms:
On power up, I can hear the motor spin up in the following sequence:
rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrr rrrr rrrr rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrr rrrr rrrr
Status lights in PC 3000 Portable are:
BSY (stays green drive does not become ready)
DRD Green
DWF RED
DSC Green
DRQ Green
CRR Red
IDX Green
ERR Red
Drive ID etc is not read.
Drive heads do not seem to be clicking - some minor soft clicking sound but not loud and chatty.
I have tried exact PCB Board swap with swapping BIOS chip but I get the same result..
I am starting to wonder if it has stuck heads but am working away from home and do not have gear to open up in clean environment. My experience is limited so someone may be able to direct me further based on the above info.
Scott
PostPosted: July 1st, 2012, 13:18
Since you have a PC3000, the procedure for determining which points to short is in there. You should re-read that section so you can solve this one without help next time.
Here are the points:
PostPosted: July 1st, 2012, 16:37
DRD Green
DWF RED
DSC Green
DRQ Green
CRR Red
IDX Green
ERR Red
I have just checked on an seagate drive to confirm the following:
If i plug a seagate drive in to my pc3000 udma without the jumper connected
I get the same:
BSY = green
DRD = green
DWF = red
DSC = green
DRQ = green
CRR = red
IDX = green
ERR = red
If i connect the jumper to set it as master then i get:
DRD = green
DSC = green
Work checking as it might just be that simple
Just for info, WD it's the other way round
Loki
PostPosted: July 1st, 2012, 16:58
Deleted message as shorting points have already been posted.
PostPosted: July 2nd, 2012, 4:21
Thanks to all for your input. Not a master issue and short did not resolve. I have sent the drives to someone with more experience.
Scott
Users browsing this forum: we3fan and 39 guests
