 Post subject: St3500418AS CC38 - failed head ?
PostPosted: October 4th, 2012, 2:56
After powering it clicks slightly few times (7-8) and spins down.
In terminal, after ctr+z and any command it shows:
LED: 000000CE FAddr: 0029DB13
Sometimes theres CC.
I think it's head failure. How probable is it ?
data recovery Poland
 Post subject: Re: St3500418AS CC38 - failed head ?
PostPosted: October 4th, 2012, 3:50
Online
Does it stop or is it always showing that?
ACELab partner
PostPosted: October 4th, 2012, 5:20
Sometimes it's :
No HOST FIS-ReadyStatusFlags 2002B001
and nothing happens
When started with hsa disconnected , then motor stop, hsa connected and motor start (few clicks)
after F3 1>N1
Failed to load overlay 00000004
PostPosted: October 4th, 2012, 7:08
I would change heads as a next step.
Data Recovery Cape Town
PostPosted: October 5th, 2012, 3:54
And trash the drive after that! :D
PostPosted: October 5th, 2012, 4:14
Do you mean it's not the head ?
PostPosted: October 5th, 2012, 4:29
I mean that the next step after changing heads is to trash the drive. :D
Don't fool yourself, changing heads is not a piece of cake...
PostPosted: October 5th, 2012, 6:53
I've done it many times so it's not a problem.
The problem is i'm not 100% sure it's the head.
PostPosted: October 7th, 2012, 12:47
Does anyone know how similar (the same ?) case 7200-t21778.html#p145930
was solved ?
PostPosted: October 9th, 2012, 4:26
It's not the head. Any ideas ?
PostPosted: October 10th, 2012, 4:59
Maybe it's the head.
The ones we've used were much older.
PostPosted: October 10th, 2012, 6:53
As an overlay cannot be loaded at startup, did you try make the drive boot EXTERNALLY (i.e. loader with PC3000 or other tool) ?
I would have checked the SA before assuming it's heads (one bad block in SA) or try the dirty tricks. HS is one of the latest resorts.
PostPosted: October 10th, 2012, 13:05
Unfortunately we don't have access to tools that supports 7200.12
PostPosted: October 10th, 2012, 15:50
I see on Russian sites that people use ST-MEM also with 12th.
Users browsing this forum: No registered users and 55 guests
