 Post subject: 7200.7 Please identify missing element.
PostPosted: October 12th, 2012, 10:04
The chip was broken in half (before completely peeled off), black plastic remain suggests resistor. I need to know value of this resistor. I have similiar 7200.7, but MPU is ST, not Agere. Strange, on this PCB connected to the same MPU pin is capacitor (brown), but I am sure it was black.
Here are PCB details and photo:
ST3200822A 72007
F/W 3.01 APLUS S.07
PCB sticker: 100299703
MPU:
AGERE 4490D6
100274360-74
100300639-83
Motor chip:
Ti 980 B
SH6950
 Post subject: Re: 7200.7 Please identify missing element.
PostPosted: October 14th, 2012, 18:56
Nothing?
PostPosted: October 15th, 2012, 6:25
I had a look for you today, but could not find an exact match.
I found a very similar board, and measured the resistance. But the reading was completely different depending on the polarity, and changed with time.
I have not studied electronics for a long time (so have forgotten a lot), but is it likely to be a capacitor?
The component is very small, and I could not see any markings on it. I will try and find a microscope to look at it.
PostPosted: October 15th, 2012, 18:57
Thanks for response.
Yes , it is very small, but colour should be noticed. Is it light brown like other capacitors or black?
If it is black, then is important to know resistance. I forgoten to mention that only meassurement on the lowest 200 Ohm range is valid. So please turn off autorange (if present) and select manual 200 Ohm range. Any higher range will open internal junctions inside chip. On my PCB resistance is outside the range.
Also please confirm that the chip this element is connected to is Agere, not ST. This is the largest chip on PCB.
PostPosted: October 15th, 2012, 20:27
Have not had a chance to look thoroughly, but as far as picture/color goes, see if this helps:
http://www.ebay.com/itm/Seagate-Barracu ... 1327497%26
Roll over the bigger PCB images at the bottom of the page, you will see a somewhat zoomed in view.
PostPosted: October 16th, 2012, 0:45
I took a few photos (only have a phone camera) and handheld microscope.
I measured the resistance (on a cheap multimeter) on the 200 Ohm scale and it read 1 (that is, off the scale).
The component is not really black, and appears the same as the component further down towards the IDE interface.
File comment: Zoomed in photo of just the component.
File comment: Zoomed in photo.
File comment: HDD label.
File comment: PCB label.
File comment: Component area, showing similar component.
File comment: MCU.
File comment: Component area.
File comment: PCB.
PostPosted: October 16th, 2012, 5:31
Cris, you are fantastic! This is definitely capacitor. Probably bypassing cap and value is not critical. I will put some around 10nF and see what happen.
Thanks Cris and Labtech.
Users browsing this forum: No registered users and 82 guests
