 Post subject: Recovery of WD5000AAJS fried board - Conflicting advice
PostPosted: October 25th, 2012, 13:12
I'm new to this.
I have a WD5000AAJS-22YFA0 Date 20May 2008. I'm looking for an outcome where I can recover over 400Gb of data.
It's been in an external enclosure, and the short circuit has fried it, there are burn marks all over the soldering and the
central Marvell rom (I think) has bubbled up the plastic at the centre of the chip.
I've found a board on ebay:
http://www.ebay.co.uk/itm/WDxxxxAAJS-WDxxxxAAKS-PCB-ONLY-Embedded-ROM-88i6745-TFJ1-2061-701477-100-AF-/271050496437?pt=UK_Computing_Other_Computing_Networking&hash=item3f1bde59b5&ssPageName=RSS:B:SHOP:GB:101
which is the same rom number and circuit board identification, i.e. 2061-701477-100 AF, as the fried board. This is where
the conflicting information comes in. Can I plug this in, and the hdd will come alive? I'm getting advice from some areas,
where I need to transfer across important data from the ROM. But the rom is fried. How would that information be
reconstituted.
Bob.
 Post subject: Re: Recovery of WD5000AAJS fried board - Conflicting advice
PostPosted: October 25th, 2012, 16:20
There's ways to recover data if rom is fried on this model but not by you. Seek pro help.
PostPosted: October 25th, 2012, 16:57
Out of curiosity, where exactly the 'conflicting advice' come from and what they say?
PostPosted: October 26th, 2012, 2:23
scope_creep wrote:
I'm new to this.
reconstituted.
Bob.
There is NOTHING you can do with this, you need a pro with the right knowledge and tools (expensive tools) to reconstruct the ROM info from the platters and write this to a new PCB.
Suggest you contact forum member "buster80" (www.databusters.co.uk) he is in Glasgow and should be able to do this for you at a reasonable price.
It's very rare for the MCU to "bubble up" like you say, so there is a possibility of further (internal) damage, but Andy will be able to tell if that's the case.
PostPosted: October 26th, 2012, 10:15
Thanks guys for the quick reponse.
Seems to reflect what i've been reading up on, the past couple of days.
I'd phoned a couple wee recovery companies down south. One said the replacement pcb might
work, the other was positive. I think he was probably trying to make a buck.
I had another look at the board mid day yesterday, and I could see burn mark on almost tall he
solder points. A lot of current was through there. Would it be possible the heads are burnt out. Is
there any thermal cutoff between the board and heads.
I'll contact buster80. Is it possible to contact directly within the forum. I see my private messaging is
off.
regards
Bob.
PostPosted: October 26th, 2012, 10:17
Check his website that pcimage linked? http://www.databusters.co.uk/contact.html
andy@databusters.co.uk
I think you need 10 posts to be able to PM members
Loki
PostPosted: October 29th, 2012, 3:39
You need a "PCB adaptation service".
The following PCB supplier provides such a service for free:
http://www.donordrives.com/services
Contact forum member porthas:
ucp.php?i=pm&mode=compose&action=quotepost&p=155031
Users browsing this forum: Google [Bot], servohunter and 99 guests
