 Post subject: Seagate HD problem, need info ...
PostPosted: October 27th, 2012, 10:40
Hi everyone,
I am hoping that someone can help with a Hard Drive problem. I have a Seagate ST31000340AS Barracuda 7200.11 1TB drive. It stopped being recognised by any BIOS in various machines I have tried it on (I have had it going for 4 years with no problems whatsoever). The drive spins up, then initialises but I just can't get it to recognise the drive. On a website it suggested buying an RS232 to TTL device and using HyperTerminal, access the drive doing a reset. Everything goes fine, I can perform a loop-back test (inputted characters come back) but as soon as I connect the drive, I get a few characters of garbage. When I press CTRL+Z, I just get a right arrow. Has anyone experienced this problem? Can anyone help? I need to get the data back on it.
Many thanks.
 Post subject: Re: Seagate HD problem, need info ...
PostPosted: October 28th, 2012, 2:46
Try your RS232-TTL device with another working drive . Maybe the problem with the ground (need common ground for pc, Hdd and RS232 device). You should get proper output on your terminal screen. Assuming that you know the settings , baud rates, connection details etc.
Checking using another working drive will isolate these issues
PostPosted: October 29th, 2012, 4:12
If all else fails, contact Seagate. If your firmware is affected by the 7200.11 BSY bug, then you may still be eligible for free data recovery.
Users browsing this forum: Google [Bot], servohunter and 91 guests
