 Post subject: I hope this help
PostPosted: June 24th, 2012, 14:33
2060-771754-000 REV A USB
Interchangeable with
2060-771692-005 REV A SATA
TESTED
I hope this help others.
Good luck
 Post subject: Re: I hope this help
PostPosted: June 27th, 2012, 16:11
Thanks for posting this!
PostPosted: June 29th, 2012, 12:00
Thanks to hddguy too :P
http://forum.hddguru.com/usb-sata-new-model-pcb-t22310.html
PostPosted: October 30th, 2012, 8:54
UPDATE :
771761- USB3 also interchangeable with 771692 SATA
Good luck
PostPosted: October 30th, 2012, 9:58
Good info, thanks unknown!!
PostPosted: October 30th, 2012, 11:09
You're always welcome my friend. :)
PostPosted: October 30th, 2012, 11:38
ALLAH BLESS YOU,
PostPosted: October 30th, 2012, 12:52
Just to add to unknown's helpful posting, this info may be helpful:
SATA BOARDS
sata board: 2060-771629-006 rev a = CPU: 88i9146-tfj2
sata board: 2060-771692-005 rev a = CPU: 88i9146-tfj2 (helios)
sata board: 2060-771629-002 rev a = CPU: 88i9146-tfj2 (helios)
sata board: 2060-771672-004 REV A = CPU: 88i9045-tfj2 p4t5740.1
sata board: 2060-701499-000 REV A = CPU: 88i6745N-TFJ1
sata board: 2060-701672-001 REV P1 = CPU: 88i9045-TFJ2
sata board: 2060-701574-001 rev a = CPU: 88i88450-BHG2
sata board: 2060-771672-001 rev a = cpu: 88i9045-tfj2
sata board: 2060-771692-002 rev p1 = cpu: 88i9046-tfj2
USB BOARDS
usb board: 2060-701675-004 rev p1 = cpu 88i9045-tfj2
usb board: 2060-701675-001 rev p1 = cpu 88i8946-tfj2
usb board: 2060-771754-000 rev a = cpu 88i9146-tfj2
usb board: 2060-771737-000 rev p1 = cpu 88i9146-tfj2
usb board: 2060-701615-003 rev a = cpu 88i6745n-tfj1
usb board: 2060-701635-001 rev p1 = cpu: 88i8845C-bhg2
If anyone else has some more sata/usb CPU numbers and wants to post, I'm sure the forum will find it helpful.
PostPosted: October 30th, 2012, 13:45
@ SALIM:
Thank you.
@ bcometa:
Very helpful indeed. Thanks for sharing.
PostPosted: November 2nd, 2012, 17:42
FYI...
Just got a usb board: 2060-701675-001 rev p1 in and the CPU is different than above. It is cpu 88i9045-tfj2.
PostPosted: November 8th, 2012, 12:23
Isn't the motor controller relevant for board swapping?
PostPosted: January 18th, 2015, 13:17
Hi ,
Can Someone Answer This Question Please ,WD Gurus
PostPosted: January 18th, 2015, 14:47
Yes it is, usually TI or Nautilus.
PostPosted: April 23rd, 2015, 11:11
hello,
Please, could you tell me if the 2060-771754-000 rev P1 is compatible with the 2060-771754-000 rev A
And if there is others pcb with sata conection I could use with this model .
thank you
PostPosted: April 23rd, 2015, 11:13
*the model I have is the 2060-771754-00 REV P1
Users browsing this forum: Google [Bot] and 55 guests
