 Post subject: WD HDD ZERO BYTES PROBLEM OF FOLDERS
PostPosted: November 2nd, 2012, 15:41
i HAVE A WESTERN DIGITAL EXTERNAL HDD IN WHICH HAVE SOME FOLDER, SHOWS THE SIZE OF ZERO BYTES.SO HOW CAN I RECOVER THE FILES FROM THAT FOLDER
 Post subject: Re: WD HDD ZERO BYTES PROBLEM OF FOLDERS
PostPosted: November 2nd, 2012, 15:59
hoW CAN I RECOVER THE FILE FROM ZERO BYTE SIZE FOLDER
PostPosted: November 3rd, 2012, 1:43
if your hard disk is detecting properly, and you are able to see other files and folders, then your problem may be due to virus or corruption of files.
try R-studio , scan the drive and check if you can see the data that you want to recover.
But if there is clicking noise or bad sectors found in the drive when scanning, then stop the scan , there may be physical damages to the drive that needs different approach.
PostPosted: November 3rd, 2012, 11:18
can u be more specific?
how did it happen and what about other files?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
Users browsing this forum: Google [Bot] and 60 guests
