 Post subject: 7200.12 2 platters motor issue
PostPosted: December 1st, 2012, 7:15
At power ON drive does not spin and flebily noises 'gn' ... 'gn'... so if motor is seized - but is not.
removed heads motor can spin without any problem manually.
already diagnose PCB and HEADS, they are OK.
resistence on wires looks fine so i would say OHM OK
since have spacer looking for a workaround before platter transplant,
if must be done will be done but you know what i mean 8)
 Post subject: Re: 7200.12 2 platters motor issue
PostPosted: December 1st, 2012, 9:09
Check if the spindle rotates freely by himself when receives power, instead of checking only by hand.
PostPosted: December 1st, 2012, 10:55
Do not even start rotate
PostPosted: December 1st, 2012, 11:28
If PCB and Heads are tested, so the only chance is damaged spindle.
Another option to platter swap is swap the spindle.
PostPosted: December 1st, 2012, 12:08
Platters swapped, but motor still does not rotate and same noises :shock:
PostPosted: December 1st, 2012, 12:31
So... not a spindle issue... another good conclusion to mess things up :)
PostPosted: December 1st, 2012, 12:54
Something not adding up. It seems like the spinning problem carries over where ever the platters go and the platters should have nothing to do with it. WTH?
PostPosted: December 1st, 2012, 13:00
So spindle issue is out of question.
I had a case where ROM was the problem.
PostPosted: December 1st, 2012, 13:02
Another pcb already tested so not rom related.
PostPosted: December 1st, 2012, 13:06
How did you test PCB ?
PostPosted: December 1st, 2012, 15:09
Hard drive under recovering problem fixed (after platter swap i badly re-assembly heads and released them near but not exactly in their resting zone causing a micro-stiction :lol: )
to say that motor in .12 is not powerful.
PostPosted: December 3rd, 2012, 5:44
Nice :)
PostPosted: December 3rd, 2012, 9:25
SEMPRE controllare due volte quando riassembli lo stack ! E' andata bene perche' poteva succedere di peggio alla partenza.
ALWAYS double check when reassemblying the stack. Everything went well, at startup a catastrophical event could have happened.
PostPosted: December 5th, 2012, 6:21
:good:
This is the kind of risk that is involved in DIY and is why we discourage users to attempt a DIY recovery themselves. IT really does pay to double check and even triple check!
Users browsing this forum: No registered users and 61 guests
