 Post subject: hdd hitachi.......ce sa-i mai fac in afara sa-i dau foc
PostPosted: December 6th, 2012, 6:25
Salut!
jumatate din parul de pe cap mi l-a albit aceasta problema..........
Am scos un hdd hitachi sata 500gb dintr-un hdtv pvr 500.1, in ideea folosirii lui pe PC, ca e pacat sa stea degeaba in reciver,asa si m-am apucat sa pun windowsul pe el,........... nu se poate, am incercat sa-l partitionez si sa-l formatez cu partition magic, norton ,paragon , acronis , easus, apoi din linux cu gpated,chkdsk, hdd regenerator, si multe altele.Daca il pun inapoi in reciver merge.Am mai facut proba cu alte 2 hdd care au mers pe PC, dupa ce le-am scos din reciver si am vrut sa bag windowsul la fel , nu mai merg.Am cumparat un cablu adaptor ca sa pot cupla hdd la laptop, ca sa-l pot ingineri mai bine, in manage/disk management nu ma lasa sa-i fac nimic nici sa-l pun on line nici sa-i fac partitii, nici sa-l fac active,imi da eroarea pe care am pus-o in attachement.Asta se intampla cu toate 3 hdd.Dupa cate am citit, hdd ar fi criptat sau ceva , intrebarea este, ssie careva sa scoata criptarea sau cheia pe care o are?
 Post subject: Re: hdd hitachi.......ce sa-i mai fac in afara sa-i dau foc
PostPosted: December 6th, 2012, 7:42
You are from Spain, write a topic in French on a English forum?!?!?! :shock: :shock: :shock:
ACELab partner
PostPosted: December 6th, 2012, 7:55
radiu wrote:
Salut!
Hello!
half the hair on my head to this problem bleached ..........
I took a 500gb sata hdd hitachi a HDTV PVR 500.1, the idea of using it on PC, it's a shame to waste time in reciver, and so I started to put Windows on it, ........ ... can not, I tried to partition and format it with partition magic, norton, Paragon, Acronis, easus, then linux with gpated, chkdsk, hdd regenerator, and many altele.Daca put it back in reciver work. I did test with 2 other computer hDD that went on after I removed the reciver and I wanted to stick as Windows regularly, not merg.Am bought an adapter cable so I can plug the laptop hdd, to I can engineer better, manage / disk management it does not let me do anything not to put it on line or partitions to make him or make him active, gives me the error we made ​​a in attachement.Asta happens with all 3 hdd.Dupa what I've read, hdd should be encrypted or something, the question is, EDSS to remove any encryption or key that is?(google translate)
PostPosted: December 6th, 2012, 12:25
Actually he is writing in Romanian language :D
www.datasave.ro
PostPosted: December 6th, 2012, 12:57
The Salut misled me eheheheheh
ACELab partner
PostPosted: December 8th, 2012, 16:44
It sounds like the receiver may have set a password on your drive for DRM reasons.
Check the security status of your drive with a tool such as HD Sentinel or HDDScan.
Users browsing this forum: Google [Bot], servohunter and 58 guests
