 Post subject: wd 1Tb Hd 3.0 restore
PostPosted: February 3rd, 2013, 2:27
hi guys,
I have used CLEAN command on my external hd and i have
tried all type of software available but still didnt got the result.
Please suggest a way to add MBR/partition table .
Data is there in hd i have extract some of the data but i want to allocate my hd as it was earlier.
 Post subject: Re: wd 1Tb Hd 3.0 restore
PostPosted: February 3rd, 2013, 12:22
How (using what )did you use CLEAN command ?
What is the problem (error )you are getting with the drive?
If you do not want the data , you can use MHDD to test the drive and ERASE the drive. REMEMBER ,ALL YOUR DATA WILL BE LOST,
You can start by telling what is the problem with the drive, how it happened and what you intend to achieve.
If you do not want data from the drive, Check for warranty and RMA it.
PostPosted: February 3rd, 2013, 20:55
Thanks for reply but i have extract all of the data and formatted the drive.
PostPosted: February 3rd, 2013, 23:55
Run MHDD from floppy/cd,
erase/fasterase (to wipe the drive)the drive and scan it to test the drive.
But you must connect the drive directly to the SATA port of the PC, not via USB.
You have not given any other details regarding the HDD and its Problem
Users browsing this forum: No registered users and 43 guests
