 Post subject: Clean room partner in the USA
PostPosted: February 11th, 2013, 17:39
Hello, I hope this is the right forum for this sort of request. If not, please advise me so I can delete this post!
I currently have a couple of Deepspar disk imagers to provide data recovery for our clients but no clean room or clean room services. The companies I have partnered with to do the clean room range of our work are quite expensive and that does not always work for our clients (who are generally not businesses).
I was wondering if there was a directory or recommendation for clean room companies in the US who work with other data recovery shops to provide a lower cost of recovery, on average, than the major nationwide chains.
Right now, the average clean room recovery costs us between $1400-$1600 and I am hoping to save my clients a bit of money by switching partners. Thanks!
 Post subject: Re: Clean room partner in the USA
PostPosted: February 12th, 2013, 6:14
Are you unsatisfied of their services? If not, I would address another customer target instead. Try to get a bit lower range, but you can't ask a cleanroom work for 500$ taxes paid.
PostPosted: February 12th, 2013, 9:18
Thanks for your call yesterday and sorry for the interruption. I was thinking about your needs and suggest that you might want to contact Jon (jonoats) @ DataSavers.
PostPosted: February 12th, 2013, 21:37
most labs will provide discounts to partners. Also if you can provide a monthly volume of cases that usually helps getting you a better rate.
