 Post subject: Raid 5 problem
PostPosted: February 21st, 2013, 18:03
Hi to all!
Please help me!
3 hdds 1 TB. Linux parttion ext3
1 parttion 1,8 TB
IBM DS5020
After the issue the User tried to edit the partition to try to read the data without success!
Tool in runtime not sucess.
rstudio... not acess view 1 partition ext3 not view folder and files...
Нет ничего невозможного
 Post subject: Re: Raid 5 problem
PostPosted: February 21st, 2013, 18:10
I'm not sure you gave enough information to get help...
Do you know the raid parameters ?
What are you hopping there ?
My best choice to solve raid 5 are a pen, paper, hex calc and winhex/X-ways if that's the kind of info you need...
Lemmy
PostPosted: February 22nd, 2013, 9:51
RAID 5 128KB LEFT ASYNC (CONTINUOUS) 3 HDDS
PostPosted: February 22nd, 2013, 10:28
1. What is "the issue" that was first encountered
2. What do you mean with "User tried to edit the partition?"
3. Can you confirm that you have cloned all three drives and are working with the clones?
4. Would you like remote assistance?
PostPosted: February 22nd, 2013, 10:46
Based on my notes for IBM DSxxxx this is not correct XOR order type.
Angel Data Recovery
PostPosted: February 22nd, 2013, 10:58
Assuming DR-Kiev is right (which is most of the time true regarding RAID I think), you can try ReclaiMe if you are not successfull with a pen and paper.
Additionnaly, lcoughey asked interesting question...
Lemmy
PostPosted: February 23rd, 2013, 2:59
Definitely vote for http://www.angeldatarecovery.com
PostPosted: February 24th, 2013, 5:22
tried it many times, and guides you to the wrong direction, 90% wrong
