 Post subject: NEED LODER FROM ST98823AS F/W 7.01
PostPosted: March 5th, 2013, 13:39
Hi guys, if you have this loder please send me. PC3000 have no resources from this drives. I have 2 drives but not compatible.
Thanks in advance
 Post subject: Re: NEED LODER FROM ST98823AS F/W 7.01
PostPosted: March 5th, 2013, 15:51
What are the symptoms of the fault?
Clicking?
This fw version drive (Apple 7.01) is a known problem drive and rarely recoverable.
Google "Seagate 7.01" :-)
PostPosted: March 5th, 2013, 16:50
Agreed. These drives are nightmare.
PostPosted: March 6th, 2013, 8:14
The heads were damaged.. I swapped the heads and at the first time I power on the drive seems to try to read but never get ready state.. After the first attempt it just nock the heads a couple of times and turn the drive of..
I soppose there is a damaged surface.. maybe in the head 0.. I was hopping to change the heads map and try to power on the drive not using that head.
pfff I know... I had more of this before but most of them unrecoverable
