 Post subject: WD unrecognizable problem
PostPosted: March 9th, 2013, 4:44
My WD20EARS got a slight hit while it fell on its side during copying files. The drive stopped working and while powered on it's making a few number of clicking before it's powered off itself.
I have access to advanced clean room so I carefuly opend the drive and looked for a head problem. Looking under magnifying glass it seems like the heads are magically intact (the black magnets seems to fit exactly in their places). I also tried replacing the PCB (even though I can hardly belive it was damaged) with an exactly the same one with no results.
My question is - Is there a chance that head problem is invisible under magnifying glass? What else could be the couse of the problem?
 Post subject: Re: WD unrecognizable problem
PostPosted: March 9th, 2013, 5:15
Heads went bad.
Yes.
Wasted time and / or money.
You need to have drive evaluated by a professional who knows what he's doing.
Heads on your drive are bad and there is nothing YOU can do about it. Having access to a clean room does not solve your problem unfortunately. Since the fall happened during read/write operation there is a big chance your drive also suffers from surface damage.
Good luck
PostPosted: March 9th, 2013, 6:17
The surface damage should be visible? I looked at the first platter and it looks crystal clear. Should I expect the other platters also be without any damage?
PostPosted: March 9th, 2013, 8:09
Not necessarily.
No. One surface can be bad, where others can be good.
Again, damage could not be visible, and you have no way of looking on other surfaces.
PostPosted: March 9th, 2013, 8:55
What chances do you think the surface has damage in case described?
Is there any way to know that before replacing the heads?
PostPosted: March 9th, 2013, 22:26
The big issue is that the drive is WD and those are known to have some problems to get the heads re-aligned when you open the lid of them
can you tell me please what should I look for while replacing the heads for not having such a problem
Also it's not so clear to me how to disassemble the heads as there's no usual screw above the head stack.
PostPosted: March 10th, 2013, 3:44
This is one question that will not get a very favoriable answer here from a professional. If you are asking this question this tells us that you have no idea what you are doing and attempting a head swap will only destroy your chances of ever finding your data on this drive. I do believe that now it is open if you stop what you are trying and send this one in to a professional company they can do this for you. But if you keep playing around on this and attempt a head swap then you are only causing more problems with this drive and will pay a higher price if you do decide to send it in for repair. I wish you very good luck on this one and do not suggest that you go further with attempting a head swap if you do not understand how to remove the heads and put in new one.
Iorana Haraharaini
