 Post subject: WD USB to SATA conversion - new PCB'S
PostPosted: March 20th, 2013, 0:16
Hi Guys,
I hope someone can help me out with this one.
I used to convert USB PCB'S of may passports 2.5" as shown in
PCB-1-S-1.jpg 7 PCB-1-S-2.jpg, this is the standard way as you can find all over the forums.
I received a 1TB drive as seen in the other 2 pictures PCB-2-S-1.jpg &
PCB-2-S-2.jpg which has completely different layout of the PCB, can someone advise how i can convert this one, which components need to be removed and where are the right soldering points?
 Post subject: Re: WD USB to SATA conversion - new PCB'S
PostPosted: March 20th, 2013, 7:59
You are facing a problem called SMARTWARE and conversion from USB to SATA in your cases it is not going to help. Do you know how to descript it after conversion?
Recuperacion De Datos Dominican Republic
