 Post subject: seagate momentus 7200.5 ST9750420AS zero LBA
PostPosted: March 14th, 2013, 9:16
Hello
I have a 750gb Seagate Momentus 7200.5, model ID ST9750420AS.
I get> HDD does not support set max LBA
and> Recalibrate error Device error detected "ABR" 51/04 .
drive capacity shows zero MB.
LBA is set everywhere to minus one "-1", cannot be changed.
What should I look out for?
Pavel
 Post subject: Re: seagate momentus 7200.5 ST9750420AS zero LBA
PostPosted: March 14th, 2013, 9:26
Sounds like a firmware issue, but what is the drive's mechanical behavior? Any weird sounds.
PostPosted: March 14th, 2013, 10:12
Spildit wrote:
Ctrl + U should dump STUFF.
Post here the answer to Ctrl+U.
What would this achieve?
0 LBA generally occurs when ID is made from ROM (i.e if SA cant read) or if SA has errors (like with bad Translator or non-native ROM). You should post terminal log, check HDD for any mechanical sounds during operation, and check that spindle remains powered after DRDY is reached
PostPosted: March 14th, 2013, 10:32
this is valid for pre F3 series only
PostPosted: March 14th, 2013, 10:48
Spildit wrote:
Seagate momentus 7200.5 is F3 arch ?
http://media.bestofmicro.com/4/Z/274931 ... B-pers.jpg
PostPosted: March 22nd, 2013, 19:35
hello.
I have a similar problem
terminal shows:
EarlySpinup Enabled
Rst 0x10M
SIM Error 2041
RW Error
[PORFAIL:MC.disabled]
What can I do??
PostPosted: March 23rd, 2013, 6:03
damian wrote:
hello.
terminal shows:
EarlySpinup Enabled
Rst 0x10M
SIM Error 2041
RW Error
What can I do??
Dear Friend Damian
Its Very Easy I Dont Think U Need To Resoved This Problem For Any Rocket Science.
Experiance And Learning Make Every Case Easy.
