 Post subject: can't burn files with long name ?
PostPosted: April 20th, 2013, 12:53
good evening ..
so a customer wants his data burned into DVD (data ~2Giga).
trying to burn the recovered files using windows 7 default burn tool , is givving errors (~580 errors) because of long files names .
trying to compress the recovered folder using winrar to burn one big rar file , is givving an error also !! that some files names are too long .
any one passed on this situation before ?
thank you
 Post subject: Re: can't burn files with long name ?
PostPosted: April 20th, 2013, 15:11
What was the filesystem type, which originally held the customer's files? In other words - was it an NTFS filesystem on the hard disk, which you recovered the files from, or some other filesystem type (explain which one) that you recovered the files from?
PostPosted: April 20th, 2013, 16:10
You need to move those folders that have long filenames closer to the root directory.
http://www.rescue-it.se
PostPosted: April 20th, 2013, 17:12
thank you for your reply .
i was trying to avoide tracking down each folder that containes files with long names , i just located them manually and moved them to a closer new folder to the root
PostPosted: April 22nd, 2013, 13:34
raven4d wrote:
good evening ..
thank you
Hi Dear Friend Raven4d
Just Move It To Root Directory Like C:your Folder Or D:/Your Folder And Make ISO Image Using UltraIso
And Burn That ISO Image Or Compress That ISO With Winrar And Burn It.
Yours Friend
Jignesh Pankhania
PostPosted: April 25th, 2013, 18:36
thank u all
Users browsing this forum: WebClaw and 32 guests
