 Post subject: Samsung Spinpoint SP2514N does not spin
PostPosted: July 14th, 2013, 18:40
I posted a request for help with a Samsung external hard drive, I was advised to repost and with lots of photos and explanation of the problem.
I have uploaded some photos which I hope are helpful. The hard drive comes out of a Freecom external drive and was purchased in the UK. The drive will no longer spin, and the blue light does not show. I suspect a power surge or I mixed up the power cables.....but it is an old drive 2006 which has worked well. I bought a C2G / Cables to Go 30504 USB 2.0 to IDE or Serial ATA Drive Adapter, but the drive still wont fire up, although the adapter works fine with some spare hard drives I have.
The PCB does not show burn marks anywhere near the TVS Diodes.
I need to buy a multi tester tomorrow
Look forward to any advice or comments thankyou
 Post subject: Re: Samsung Spinpoint SP2514N does not spin
PostPosted: July 15th, 2013, 2:38
see the 2 resistors marked 0 in the second to bottom picture? Try putting a pair of tweezers each one them to "short" or bypass them when it is plugged in to see if they are open circuit or not. Also, not sure if the large black component on the extreme left of the same picture is a fuse or not. it could be open.
I think I have a few of those drives so I can maybe compare components when I get home in a day or so
PostPosted: July 17th, 2013, 23:46
File comment: I tested the resisters and they read 0 and the multitester beeps
File comment: I tested the Diode and this reads 0 and the multitester beeps
File comment: I tested the other diode which tested 540 but multitester did not beep
PostPosted: July 17th, 2013, 23:54
HaQue, Thankyou for your help, I bought a multitester today, so tried this out.....didn't I didn't know what to look for when testing with tweezers to see how they shorted or not. Hope the phots help
Cheers!
PostPosted: July 18th, 2013, 0:51
It's a TVS and the middle picture seems to be showing that it's shorted - needs to be double-checked IMHO, if the OP is taking the risks of DIY.
PostPosted: July 18th, 2013, 9:08
Vulcan, thanks for your input - Its a TVS as you say - I showed the relevant photos to the suspected problems. I need to work out what is the best solution to recovering the data, I read how others have had similar problems and were able find help in the forum. I tried to follow the advice on their posts but I need to confirm the right steps to take before I do anything drastic
PostPosted: July 18th, 2013, 10:29
well you could replace the TVS Diodes with the same type as a start.. or read up, as I think I have read you can remove them to ONLY copy data, not a long term solution.. if this is indeed your problem
PostPosted: July 18th, 2013, 15:03
I think I would remove them to copy data, the drive I would scrap. Is that all that is required - remove the one that shorts?
PostPosted: July 18th, 2013, 15:59
I removed the TVS Diode which was shorting, the hard drive starts up now...but has three clicks after which it stops spinning and does not show up on the computer
PostPosted: July 18th, 2013, 16:01
70% Headstack is gone.
30% PCB is gone.
Game over for DIY in any case.
PostPosted: July 18th, 2013, 16:04
Can also be :
70 % headstack is gone
25% PCB is gone.
5% firmware problem.
Game over for DIY anyway.
PostPosted: July 18th, 2013, 16:46
Agree......I took apart another Samsung hard drive very similar construction, i bought it just to see what goes on inside....this too was clicking. I looked at the heads......they looked like they touch the disc, but cannot really see at this scale.
I thought this video was interesting but, but finding a donor head assembly for my 250 hard drive is a long shot. So it looks like professional data recovery is the only thing left
http://www.youtube.com/watch?v=Q9AoMeHRIPU
BlackST wrote:
Can also be :
25% PCB is gone.
PostPosted: July 22nd, 2013, 0:36
If you can get a terminal report from the drive, that may provide more information. There are instructions for other Samsung models at The HDD Oracle.
Users browsing this forum: No registered users and 88 guests
