 Post subject: wd3200bpvt - 24zesto Suitable to wd3200bpvt - 00zesto
PostPosted: August 4th, 2013, 23:31
i have problem with my hard disk wd3200bpvt - 00zesto
make noise Click Click Click
if i change in clean room the heads It is can work?
wd3200bpvt - 24zesto to wd3200bpvt - 00zesto
or do i have the same one?
 Post subject: Re: wd3200bpvt - 24zesto Suitable to wd3200bpvt - 00zesto
PostPosted: August 12th, 2013, 14:09
You might want to have similar DCM
Hard Drives For Sale
Largest hard drive supplier for data recovery purposes
More than 10,000 hard drives in stock and ready to ship
PostPosted: August 13th, 2013, 9:44
Equal DCM will not mean you will be sucesseful.
Are you experiences in head swaps first of all?
PostPosted: August 14th, 2013, 5:16
i tried to change but without successful
it cannot read this
and yes i do it before i have the lab and the tools for this
PostPosted: August 14th, 2013, 5:27
So, and if you return donor heads into donor drive, are they still working?
PostPosted: August 14th, 2013, 10:13
You should check for media damage on patient heads before trying anything.
PostPosted: August 20th, 2013, 0:13
yes its work
PostPosted: August 20th, 2013, 3:13
Ok, that's something.
And with the new heads, does the patient knocks or what?
Users browsing this forum: Bing [Bot], Google [Bot] and 80 guests
