Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: DiamondMax22 fw MX1A strange PCB - terminal log TetonST
PostPosted: July 25th, 2013, 5:09
No.
When the original pcb is isolated i enter command Z and i receive the normal message of spin down.
Then i remove the insulation paper and enter U command but i receive R/W error
My firmware database:
PostPosted: July 25th, 2013, 5:23
If you dont see the TetonST boot then I guess ROM is ok, your donor PCB may not be compatible.
After spinup, what is the fill error you see? Also, with native ROM + PCB does it remain powered or does its spindle shut off? Did you check SN at ID when PCB is isolated? Does it match the label of the HDD?
PostPosted: July 25th, 2013, 5:33
Original PCB 100475720 + native ROM log
'PCB isolated'
Rst 0x20M
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.138 msecs
'PCB connected'
F3 2>U
DiagError 00006008
Spin Error
Elapsed Time 12.783 secs
R/W Status 2 R/W Error 84150180
F3 2>
'Drive still spinning'
Serial at offset 0x61644 of the ROM dump, match the one written on the label.
PostPosted: July 25th, 2013, 5:55
I think you need to try new PCB, one with same code as your native PCB and transfer ROM over
PostPosted: July 25th, 2013, 6:14
Right now i don't have donor 100475720, i used as donor pcb 100466725 because is the only one i have and usually on this drives you see this pcb model.
100475720 on DM22 STM3500320AS are unusual.
But if you say that the exact pcb swap will work, i will try it.
Thanks.
PostPosted: July 25th, 2013, 6:18
Thanks.
From your output there is definately some 'hardware' error. Spindle remains powered, you have T> and you get error on spin-up. Im not certain its anything without seeing it, but at this stage PCB is a good assumption.
PostPosted: July 25th, 2013, 6:20
ok i will try, i can find a donor for 20$ (including shipping cost)
PostPosted: August 28th, 2013, 9:50
I changed the pcb 100475720 today (obviously i transferred the rom), but i still have same issue.
Head clicking on spin up command in terminal, but it doesn't spin down
'PCB connected'
F3 2>U
DiagError 00006008
Spin Error
F3 2>
Users browsing this forum: Google [Bot] and 70 guests
