PCB Replacement Question
August 26th, 2013, 18:13
Hello all,
Computer repair tech here looking to get more into the hard drive recovery side of things. I have a spare drive which is faulty (no sound whatsoever when plugged in). From what I read, this is likely a PCB issue.
I am looking for a replacement PCB according to the PCB number (2061-771672-F04). eBay has a few but it looks like they are from slightly different models (mine is a WD5000BEVT).
If I were to purchase a PCB with the same PCB number, but for, say, a WD50005000PVT instead, could I just swap the rom chip? Thank you!
Re: PCB Replacement Question
August 27th, 2013, 3:12
You need to buy a PCB from same drive model, or else from same family if you can identify it.
August 27th, 2013, 3:14
dmarques wrote:You need to buy a PCB from same drive model, or else from same family if you can identify it.
What would qualify as same family?
August 27th, 2013, 3:30
What is the drive full model?
August 27th, 2013, 13:52
WD5000BEVT- 80A0RT0
DCM: HBNTJHB
Date: 14 Apr 2010
August 28th, 2013, 3:25
That one is Mariner family.
August 28th, 2013, 3:47
thank you.
I forget the guys name, but I remember watching a video series that said I should come within about 2 (weeks?) of the date on the drive, and there was something about needing the 5th or 6th correct of the DCM code to be the same. Does that sound right?
August 28th, 2013, 4:05
You may refer to Scoot Moulton.
But in this case what he said does not apply, as he's refering to heads swap on that video.
August 28th, 2013, 14:03
dmarques wrote:You may refer to Scoot Moulton.
gotcha, thanks! So in this case I would just need the same model pcb and to do a rom chip swap?
August 28th, 2013, 14:10
This supplier will swap U12 for free:
http://www.hdd-parts.com/12102804.html
August 28th, 2013, 14:34
Thanks. They seem a bit pricier than going through eBay, though.
Also, when you say U12, you're talking about the rom chip with 8 legs?
August 28th, 2013, 15:47
bascotie wrote:Also, when you say U12, you're talking about the rom chip with 8 legs?
Yes.
August 28th, 2013, 16:07
Yes.
Thanks, and sorry about the newbie questions :)
August 28th, 2013, 21:23
In the similar question,
I just happened to get another hard drive (this one is for a customer) that doesn't make any noise when connected, so I assume it also needs a pcb swap.
What do you guys usually search for when trying to find a similar pcb?
the model is wd5000bevt-75A0RT0
and the PCB # is 2061 771672 F04 AA XS AB42 5M56 5 0002060 1062
Can you tell me if this eBay PCB will work for this, as long as I swap the firmware chip?
http://www.ebay.com/itm/WD5000BEVT-22A0 ... 232eb07e33
August 28th, 2013, 21:40
To make sure I'm understanding correctly. Please let me know if this situation works:
I have a WD5000BEVT-24A0RT0 (for example!)
I need to swap the pcb and lets say my pcb is 2061-771672-F04 AA
So I go on ebay and search for 2061-771672-F04.
Let's say I find that PCB but it came from a WD5000BEVT-55A0RTO.
According to http://files.hddguru.com/download/PC-30 ... y/Mariner/
they are from the same family, so as long as I swap the bios chip, I'm ok?
August 28th, 2013, 23:51
Sorry, ignore the first questoin, but I'm just wondering about the second concerning the Mariner family and whether they are compatible
