 Post subject: wd1001fals-00j7b0 bsy
PostPosted: October 2nd, 2013, 16:25
good evening ;
i have this 1 TB drive that keeps bsy , even in kernel mode ! any ideas to fix the drive ? no data is required ..
am suspecting a corrupted ROM
thanks
 Post subject: Re: wd1001fals-00j7b0 bsy
PostPosted: October 3rd, 2013, 10:57
i don't think it's about rom at all .what tools you work with ?
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: October 3rd, 2013, 13:17
Hi
Short the pins of head reading channel same like Seagate Hdd to get ready status and access of firmware.
Thanks,
Waqas Ali
PostPosted: October 4th, 2013, 4:22
thanks for the replies ..
am using dfl wdii , and the drive in not getting ready neither in normal nor in kernel mode
waqas_ali766 , have u tried this trick before ?? and shorting the channels (if succeded will give access to the rom only .. )
thanks again
PostPosted: October 4th, 2013, 5:13
Hello
Does the drive spin up ?
Good Luck
Récupération de Données
PostPosted: October 4th, 2013, 5:18
yes , without any abnormal sounds ..
Users browsing this forum: Zeelo99 and 72 guests
