 Post subject: help required for HDD partition recovered
PostPosted: October 15th, 2013, 13:01
hi
i m shriniwas,
i have Toshiba HDD of HP Probook 4430s. some days before my laptop got stuck when booting windows xp. when i trying to format drive c: my remaining partition also got deleted. after that i check the bios setting, in that the "Hard drive protect" option was enabled. but hence there is no passward was set in the bios. i tried to repair the partition with various data recovery software but nothing happens. i also trying to solved the problem with bootable "MHDD 4.6", it shows the "drive is not ready". when i use the same drive as external drive via usb connector it works fine but the HDD shows clear (no dat/blank).
i m very apprisheat if some one solve the problem.
thank u
 Post subject: Re: help required for HDD partition recovered
PostPosted: October 24th, 2013, 12:01
You need to scan the disk whit a data recovery software like GetData or Power data recovery. The partition should be recovered if you didn't over wright the disk.
Good Luck
PostPosted: October 24th, 2013, 22:23
I m already tried with getdata back and power recovery but the process get stuck at serton sector and do not processed further.
PostPosted: October 25th, 2013, 0:52
You should clone the drive first, and then work with the clone.
Use Media Tools Pro or similar program.
http://www.rescue-it.se
PostPosted: October 25th, 2013, 2:52
Agree, or dd_rescue. It's free! :-)
PostPosted: October 26th, 2013, 17:59
ISTM that the drive has a physical problem.
