 Post subject: Question about migrate a PCB ROM
PostPosted: February 10th, 2014, 13:52
i was just wondering because i never tried this out.
When you have a fried pcb usually you change the PCB and migrate the ROM if it's needed to a donor PCB that exactly matches the fried one.
I was wondering actually needs to really identical both PCBs?
Using an example like WD
PCB Number: 2060-771698-002 REV A
PCB Sticker: 2061-771698-802 AA
what i have a donor that have this (this number is fake btw)
PCB Number: 2060-771695-001 REV B
PCB Sticker: 2061- 771695-796 AG
Can be that compatible?
 Post subject: Re: Question about migrate a PCB ROM
PostPosted: February 11th, 2014, 17:40
Sometimes it can work. Sometimes, you may find that on one PCB microcode is internal, and on the other PCB it is external, resident in a Flash chip. So you would need the right tools as always, but yep, it does work sometimes.
PostPosted: February 14th, 2014, 17:14
Good to know :)
But the numbers need to be almost the same
Thanks for the answer
PostPosted: February 17th, 2014, 12:15
Going on the PCB numbers you provided you're talking about WD and it's straightforward, match the number etched into the PCB, example 2060-771698-002. I've never found the revision (REV) or sticker on the PCB to be of any use in finding a PCB donor.
This is assuming that your PCB has U12 (ROM is at U12 and not in MCU).
Seagate, match the PCB number again. You'll often find that 2 PCBs with the same PCB number will have MCUs made by different manufacturers.
Data Recovery Cape Town
PostPosted: February 18th, 2014, 12:21
Yes i understand that, my question it's because sometimes i have same pcb but i prefer to buy another with more similitude because i don't know what could happen if i migrate the rom in that case.
Users browsing this forum: lcoughey and 75 guests
