 Post subject: WD PCB number match
PostPosted: April 4th, 2013, 6:16
for matching donors PCB, which numbers are important
WD5000AAKS-00C8A0 PCB 2060-701477-002 Rev A
WD5000AAKS-00YGA0 PCB 2060-701477-002 Rev A
WD5000AACS-00ZUB0 PCB 2061-701477-002 Rev A
WD5000AADS-00S9B0 PCB 2060-771640-003 Rev P1
 Post subject: Re: WD PCB number match
PostPosted: April 4th, 2013, 7:41
Hello Jerovsek
Here is link for you http://www.pcb4you.com/pages/western-di ... equirments
Bare in mind you will need Firmware Adaptation Service.
Recuperacion De Datos Dominican Republic
PostPosted: April 4th, 2013, 8:37
a white label with some revisions and long number starts with 2061.... this number should not be taken as reference to your PCB because it`s a serial number from the PCB and it is not possible to find match for it so please ignore it.
Great advice :lol:
The 701477 is most important, but the extensions to it can sometimes relate to the motor IC so sometimes you need to match the latter part also.
There are several cross compatible PCBs, and some PCB codes can be found on multiple different disks. 701477 for example is found on Tornado and Spider series...
PostPosted: April 4th, 2013, 8:42
Dear DRforensic and Hddguy ( :oops: )
thank you for both of your replay
Jure
PostPosted: March 27th, 2014, 23:12
Banned User
2060-701477-002 & 2060-771640-003 are important.
Western Digital Hard Drive PCB Swap Replacement Guide:
Match the board number which is etched on the PCB.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 93 guests
