 Post subject: Read Disk I: at position X: fail after 1 attempt
PostPosted: April 1st, 2014, 14:00
I have a WD 2.5 inch drive; it spins normally. HDD is recognized in Disk management, in Windows explorer it is recognized but responds very slowly. The disk has two partitions, G (System disk) and I (data disk). I am able to image G, the first 100 Gbyte without a hitch using R-Studio. But, partition I, the last 132 Gbyte, is showing the above error every 12 sectors.
What do you guruºs think is the problem ?
 Post subject: Re: Read Disk I: at position X: fail after 1 attempt
PostPosted: April 1st, 2014, 14:40
Maybe a scratch or bad/weak head or firmware problem.
PostPosted: April 1st, 2014, 17:50
sounds like a common problem, but you will need access to fw.
https://www.mjm.co.uk/
PostPosted: April 2nd, 2014, 9:09
I think the problem is that the hard drive clearly has physical issues (firmware possibly being one of them). You should either outsource to a data recovery pro or, at the very least, try to get a full sector-by-sector clone of the drive with a program like ddrescue prior to attempting a file system recovery.
PostPosted: April 2nd, 2014, 15:04
Thanks gurus.
In my opinion, the fact that the unreadable sectors occur at a regular interval without exception makes a scartch quite improbable.
Scratchy,
Will Sediv will do for firmware access ?
Thanks.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 95 guests
