 Post subject: samsung 60 gb hdd neither format nor delete partition
PostPosted: April 16th, 2014, 2:29
sir
i have a 60 gb samsung hdd there are three partitions in this. The problem with this hdd is that no file and folders deleted form this hdd. I try to format this hdd and delete partitions with many partitioning softwares but no result an error occurred "unable to write mbr". I try to edit mbr but mbr not modify with any software . At last I try to zero fill it with samsung and other softwares zero fill process finished successfully but partitions and files,folders still as it is.Please help me how can i delete partitions or zero fill this hdd.
Thanking you
your faithfully
 Post subject: Re: samsung 60 gb hdd neither format nor delete partition
PostPosted: April 16th, 2014, 2:32
It's READ ONLY problem. Replace the HDD
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
