 Post subject: how to change 2060-701292-002 with 2060-001292-000 ?
PostPosted: April 1st, 2007, 10:58
salam alekm hi
what i want is change burned pcb 2060-70129
2-002 with good 2060-001292-000 and this what i do
1- i change the rom from bad pcb to good pcb
2- i switch the pcbs but still hdd read as sabre or mamoth
and what i want is change 701292-002 with 001292-000 and get right firmware in bios so that i was asking is there any thing other rom i must move from bad pcb to the good one to get right firmware
please add me maxword5@hotmail.com
 Post subject:
PostPosted: April 1st, 2007, 11:16
No, there is no other ROM.
Either the boards are incompatible (check individual chips, I think they will be different), or you have another problem (firmware or physical).
My guess is the board is wrong, try a board of same p/n
 Post subject:
PostPosted: April 1st, 2007, 11:33
Logical boards 2060-701292-000 & 2060-701292-002 have compatible Hardware...
On PCB 2060-701292-002 are added additional TVRs (Transils) D5 & D6
Utils for WDC HDD
Mikippp
 Post subject: can switching the cpu chip do it
PostPosted: April 1st, 2007, 12:02
salam alekm can switching the cpu chip do it or i must switch all
and what is d5 d6?
 Post subject: Re: how to change 2060-701292-002 with 2060-001292-000 ?
PostPosted: April 21st, 2014, 23:24
Banned User
You need to move your original PCB's BIOS to the replacement PCB. The 8pins (4 pins on each sides) with 25P05VP、25P10VP、25F512、25F1024、25F1024AN、SST25VF512、SST25VF010, etc. are the BIOS.
PostPosted: April 22nd, 2014, 3:28
Thank you gurudata for trawling up a 7 years plus thread! :lol:
PostPosted: April 23rd, 2014, 15:11
701292 and 001292 is that work on alternative is my own experiance after swap rom you saw wd rom erorr its means your rom and sa module are not matched its my opinion :D
Users browsing this forum: Google [Bot] and 39 guests
