 Post subject: ST3500320AS SD1A Rst 0x20M loop
PostPosted: April 23rd, 2014, 7:55
I have a Seagate ST3500320AS with the SD1A firmware. It stop working after longs years of good work.
With the serial cable I can see these messages in loop :
Rst 0x20M
LED:000000CC FAddr:000107B3
Rst 0x20M
Rst 0x20M
Rst 0x20M
The motor seems to running (good vibration). I can hear spin-up try synchronize to each messages.
I can access to the diag prompt (head disconnected) but I have errors on /2 Z command and on /2 U command.
Do you think it's a PCB problem ? A swap ROM with another same PCB would help me ?
Mussat
 Post subject: Re: ST3500320AS SD1A Rst 0x20M loop
PostPosted: April 23rd, 2014, 8:31
Post full terminal log including commands output for 'U".
PostPosted: April 24th, 2014, 3:48
Logs of the terminal with somes comments:
// normal power on
Rst 0x20M
Rst 0x20M
Rst 0x20M
Rst 0x20M
Rst 0x20M
// head disconnected power on (no vibration)
F3 T>
F3 T>/2
F3 2>Z
LED:000000EE FAddr:0000F980
//freeze
// head disconnected power on again (vibration seem ok)
Rst 0x20M
F3 T>/2
F3 2>Z
LED:000000CE FAddr:00259C49
Rst 0x20M
F3 T>/2
F3 2>Z
Rst 0x20M
F3 T>/2
F3 2>Z
Rst 0x20M
// connect heads (remove paper)
F3 T>/2
F3 2>U
// freeze
// normal power on
Rst 0x20M
Rst 0x20M
Rst 0x20M
PostPosted: April 24th, 2014, 9:29
on the 'Z' command, the drive should spin down. Yours is not. It looks like the steps are not executed correctly.
PostPosted: April 24th, 2014, 9:51
What are the goods steps ?
PostPosted: April 24th, 2014, 10:01
Take to a data recovery professional before it is too late.
PostPosted: April 25th, 2014, 3:41
Thank you for your advise, but datas aren't so critical and I'd like to repair it by myself, to improve my skills and it's a challenge !
Do you know what are meaning errors code : (LED:000000CC, Rst 0x20M, ...) ?
Tanks
PostPosted: April 25th, 2014, 15:31
According to the terminal log you've posted, the problem is either dead heads or non-original PCB.
The easiest way to check the latter for this drive is to unscrew the PCB and power it on.
Users browsing this forum: Google [Bot] and 39 guests
