 Post subject: Internal error.
PostPosted: April 28th, 2014, 12:46
Dell Desktop Computer - Vista
Current date and time: 28/04/2014 17:30:30
Hard Disk Wipe Tool 2.35 build 1178; http://hddguru.com
Device details for ST3320620AS 3.ADG [320.07 Gbytes]
Details are unavailable: Internal error.
Please post this problem on http://forum.hddguru.com
trying to fix Hdd drive that a bug seems to have created an overlay? hidden partition?... computer knowledge limited
Any advice would be appreciated
Fred
 Post subject: Re: Internal error.
PostPosted: April 28th, 2014, 14:39
Hi. Fred I would start with a free utility like Mhdd or Victoria.
First check the smart attributes to help diagnose the drive condition. If you are unsure of the results you could post a screenshot in this thread.
Then I would scan the surface media with the remap option enabled. After this I would run the Hard disk wipe tool and see if you still have an internal error.
PostPosted: April 28th, 2014, 20:12
Hi Dick,
Apologies for my previous post...I'm a bit tired misread what you wre saying...Checked the smart attribues there were about three items showing as unknown. As for the surface scan, as that will take some time I will do it later on today. Rhpa and current are same. Drive is showing under PCI Controllers not sure if that is right?
MHDD saved Scrn shot to log, but haven't found where its been put? something else for later on today.
Config of drive states: Drive does not support Device configuration Overlay, not sure if that is relevant?
Once again my apologies for being a bit dumb and thanks again for your assistance
Kind regards
John
PostPosted: April 29th, 2014, 4:43
Hi Dick,
Smart Attributes as Follows:
Attrib Name Val Worst Raw
001 Read error rate 114 95 65377023
003 Spin-Up Time 97 94 0
004 Number of Spin-up Times 97 97 3113
005 Reallocated Sector Count 100 100 0
007 Seek Error Rate 87 60 479400236
009 Power-on Tme 74 74 23224
010 Spin-Up retries 100 100 0
012 Start/Stop Count 97 97 3092
187 Unknown 100 100 0
189 Unknown 100 100 0
190 Unknown 61 51 656867367
194 HDA Temperature 39 49 39
195 Hardware ECC Recovered 90 51 31797304
197 Current Pending Sector 100 100 0
198 Off Line Scan UNC Sector 100 100 0
199 Ultra ATA CRC Error Rate 200 200 0
200 Write Error Rate 100 253 0
202 Unknown 100 253 0
Sorry no screenshot- don't have a floppy.
ran surface scan to see what it does, but haven't wiped the drive yet as i thought it best to wait your comments on above, before doing another reinstall.
Much appreciated for you help
Kind regards,
Fred/john
PostPosted: April 29th, 2014, 5:20
Don't worry about the unknown entries.
I think you are ready to go with the scan with remap option enabled.
Just one thing would be the Hpa overlay if there is one.
What make and model of drive do you have and how many lba is it showing?
If there is an overlay you need to remove it first. I often use Victoria for Windows to remove it. Then run the scan with remap set to 250 or 240 in Mhdd.
PostPosted: April 29th, 2014, 6:27
Hi Dick,
Drive is Segate 320GB ST3320620AS: Mhdd says LBA is 625142448: Cache 16384: size 305245mb ?
Not sure if there is a HPA : Mhdd Config says Drive does not support Device configuration Overlay.
MHDD also reports Auto detect is not enabled but haven't worked out yet how to view MHDD.config file to adjust settings, all i get from config is, as above.
Believe problem caused by bug(whatever) creating an overlay! but as i have said my knowledge is very limited!
Will down load Victoria. but will wait for you to confirm to proceed before doing anything.
Many thanks for your assisance
Fred
PostPosted: April 29th, 2014, 10:46
Lba is correct so I think you are ready to go with the scan with remap.
Mind you the following smart attributes don't look that healthy.
You don't really have anything to lose by continuing but bear in mind you have an old drive which has had many hours of use so unless it is properly refurbished it might never be a reliable drive.
Yes run Victoria with remap set to 250 and allow the scan to complete.
PostPosted: April 29th, 2014, 11:09
Thanks...will give it a try and let you know the outcome
PostPosted: May 2nd, 2014, 14:19
Hi Dick,
Problem resolved.
Many thanks for your assistance.
kind Regards
Fred
Users browsing this forum: Google [Bot] and 40 guests
