October 14th, 2013, 17:05
October 14th, 2013, 18:33
October 28th, 2013, 8:16
ShaneWard wrote:If your drive is exactly the same as the one above, then do you see this component in the image, I think it might be some kind of fuse that is blown. If you can test the voltage on either side, it might give you an idea if it works or not, then just replace the fuse or short it with a wire. However, I beleave the fuse acts as a resister as well, so you might overcurrent the smooth chip. Replacing the S component, if its blown, might be your best bet.
fzabkar wrote:@jbonlinea, could you measure the voltages at each of the pins of your USB port on your motherboard?
Could you provide a clear, detailed photo of your HDD board?
I think I see a fuse, but I'm not certain.
Here is the USB pinout:
http://pinoutsguide.com/PortableDevices ... nout.shtml
Pin #1 is arrowed in the photo. There is a mystery component to the left of the arrow.
OttoH wrote:@jbonlinea
maybe this information helps:
this HDD is used in a Toshiba Canvio USB 3.0 500GB external Drive (HDTC705EK3AA) that I have bought recently in the online store of the german Mediamarkt. (also available at amazon.de)
October 29th, 2013, 5:09
October 29th, 2013, 13:36
October 29th, 2013, 17:00
May 14th, 2014, 14:14
May 14th, 2014, 14:50
May 14th, 2014, 14:55
May 14th, 2014, 15:07
cmcraeslo wrote:Which chip exactly is the rom?
May 20th, 2014, 18:51
