 Post subject: any way to fix corrupt adaptives without selfscan ?
PostPosted: May 23rd, 2014, 11:56
Galaxy 7200.10 3.ADG
the drive was in a flood and the original pcb is burned completely through
whether I boot from the platters or from a ldr I cannot get the drive to go ready
at the end of a heads test, it complains about corrupt adaptives
is there any way to fix corrupt adaptives without selfscan ?
any other thoughts on how to access this drive would be much appreciated
4096k x 32 DRAM
GALAXY - 1_Disk S-6B 08-30-06_15:36
Buzz HM SFI
(P)SATA Reset
Failed sys sect. write! Nwt Er 33 RdWr 15db5.00.0003
DiskAccess ReadSector EC=43 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 15db5.00.0002
Unable To Load Overlay 01|000A
T>Reset
4096k x 32 DRAM
F>HM SFI
F>B230
T>
T>T4
Begin Test 04
ASCII logging on
Buzz HM SFI
ASCII logging off
ASCII logging on
Kick Off Test
Testing head 0...
DAC value = FE1B
Biasing with current 0025mA
DAC value = FD12
Biasing with current 0050mA
DAC value = FC09
Biasing with current 0075mA
DAC value = FB00
Biasing with current 0100mA
DAC value = F9F7
Biasing with current 0125mA
DAC value = F8EE
Biasing with current 0150mA
DAC value = F7E5
Biasing with current 0175mA
DAC value = F6DC
Biasing with current 0200mA
DAC value = FE1B
Passed Max OD Bias Current = 0200mA. Limit = 0100mA
HM SFI
Testing head 1...
DAC value = FE0E
DAC value = FD05
DAC value = FBFC
DAC value = FAF3
DAC value = F9EA
DAC value = F8E1
DAC value = F7D8
DAC value = F6CF
DAC value = FE0E
HM SFI
Testing head 2...
$SFI
AMR
DAC value = FD16
DAC value = FC0D
DAC value = FB04
DAC value = F9FB
DAC value = F8F2
DAC value = F7E9
DAC value = F6E0
DAC value = F5D7
DAC value = FD16
HM SFI
Testing head 3...
DAC value = FE1D
DAC value = FD14
DAC value = FC0B
DAC value = FB02
DAC value = F9F9
DAC value = F8F0
DAC value = F7E7
DAC value = F6DE
DAC value = FE1D
HM SFI
!!! Adaptives corrupt !!!
ASCII logging off
Test=50, Feature=0, cumhlth=209c, curhlth=208c
AbEnd Test 04
Code - CF Track 00059(00067).0.000 Sns 000 Rty F7FF.50.80FF Rtf 1800 LBA 00002501
T>
 Post subject: Re: any way to fix corrupt adaptives without selfscan ?
PostPosted: May 23rd, 2014, 13:29
Have you opened the drive to verify there is no internal damage?
 Post subject: Seagate 7200.10 Galaxy remote data recovery
PostPosted: May 23rd, 2014, 14:45
Such problems may appear due to the heads' inability to write anything.
If you have PC-3000, most likely we'll be able to get the drive to READY state remotely.
If not, then considering the information above, job still looks pretty recoverable.
PAKComputers wrote:
T>
T>T4
Begin Test 04
But please do not launch tests like T4 and other selfscan tests, that may worsen the situation.
T4 is quite useless for judgements about heads and adaptives condition.
 Post subject: Re: Seagate 7200.10 Galaxy remote data recovery
PostPosted: May 26th, 2014, 20:15
Spildit wrote:
I've checked this drive remotely and i was able to reach readiness with pc3k by using the active utility on DE.
Got it. If you're on it already, then please go on, we won't interfere.
PostPosted: May 27th, 2014, 14:11
Hi there !
I'm not working on this drive. I've tried out all that i could, and concluded that either the platter was contaminated and killing the heads or the heads used for the swap were not fully compatible.
If you can help further please contact the original poster because i don't have enough knowledge to retrieve the data from this particular drive.
Thanks and best regards, and please DO help !
Users browsing this forum: No registered users and 68 guests
