 Post subject: Question about terminal commands
PostPosted: June 12th, 2014, 17:19
Hi I have a Hitachi HDD, as I connect it to the terminal and then connected that I use commands.
 Post subject: Re: Question about terminal commands
PostPosted: June 12th, 2014, 22:41
Comments by any other expert on hitachi drive, other than advice of expensive tools.
PostPosted: June 13th, 2014, 10:15
No sir, just searching the web.
PostPosted: June 15th, 2014, 4:07
hi longlife, is very upsetting you're asking for help and advise and when when someone take the time to reply you write:
i think none added any help more as spildit reply was correct.
may be the less expensive option is to buy a new drive, instead of a tool that you need to learn to use.
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
Users browsing this forum: No registered users and 37 guests
