 Post subject: Sediv latest verion 39923
PostPosted: June 20th, 2014, 8:58
Today we release the new version of Sediv for WD software.
1.ATA scan have more option, erase , scan , add track
2.Add easy button to load overlay 5C on 17XX , 18XX , 19XX PCB hard disk, before user need to open Extended buffer to write 5C overlay, now one button to load 5C overlay, here is video of loading 5C overlay, this video have old method to upload 5C module, in new version we add 5C button near 12 overlay loading
http://www.youtube.com/watch?v=rwK40FJlxDg
3. Some bugs or process uses fixed
4. WD reset function optimized
Waqas Ali
http://www.sediv.net
http://www.hddrepairing.com
 Post subject: Re: Sediv latest verion 39923
PostPosted: June 21st, 2014, 4:01
Hi Waqas,
Please provide a link.
Thanks.
PostPosted: June 21st, 2014, 4:02
Hi
http://sediv2008.narod.ru/SeDiv39923.rar
Rgds
www.datasave.ro
PostPosted: June 21st, 2014, 4:25
Sediv download has a password to extract the rar file.
Password: 01234567890
Loki
Also note I don't think it runs on 64bit OS as I've tried Win7 64bit & get an error.
Sediv is a 32bit program.
If you run it & get an error go in to task manager & check if the app is still running after you close the error.
If it is end task as the sediv can hog cpu usage.
PostPosted: June 21st, 2014, 14:48
Please explain how to do the update. I have replaced the old exe file with the new one; but, I do not know what to do with the ini file. The current ini file and the new ini file have many lines in common. If I copy and past the new ini file to the bottom of the old one, there will be many repeatitions.
Please provide precise steps to do.
Thanks.
PostPosted: June 22nd, 2014, 1:52
There is no need to change INI file. USE 3.9.9.2 version INI
Waqas Ali
PostPosted: June 24th, 2014, 19:55
what about base.mdb its not working with this update ??
