 Post subject: Seagate 7200.10 ST3320820AS 320GB
PostPosted: June 22nd, 2014, 21:19
I have a PC from a friend to fix. HDD has issues. I have a new drive, but I just wanted to see if anything could be recovered fairly easily.
Connecting with a SATA-USB, Windows says it needs to format the drive, DMDE doesnt see the drive, neither does disk management.
Doing a search, I have seen reference to a "Pending" bug on 7200.10 drives, and solutions using a loader and other tools. So looks like not DIY?
Terminal is below, and the reason I posted the whole lot of seemingly identical error types is the last line. :
Reset
4096k x 16 DRAM
GALAXY - 1_Disk    S-6B   08-30-06_15:36
Buzz HM SFI
(P)SATA Reset
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0000
ATA St 50 Er 00 Op ef a,0000/0/00,45 45 03
Niwot:  97f29ff7  b6  97f29ff7.1.842 0000  005f 0000 005f
CE Log ErrCode=43  LBA=252b183a  Type=4  Remove from Pending 252b183a
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0005
Niwot:  9ff79ff7  b6  9ff79ff7.1.842 0000  005f 0000 005f
DiskAccess ReadSector EC=43 at 01d36d.01.0005
CE Log ErrCode=43  LBA=252b183f  Type=5  Add To Pending 252b183f
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0006
CE Log ErrCode=43  LBA=252b1840  Type=4  Remove from Pending 252b1840
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0007
DiskAccess ReadSector EC=43 at 01d36d.01.0007
CE Log ErrCode=43  LBA=252b1841  Type=5  Add To Pending 252b1841
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0008
ATA St d0 Er 00 Op ec a,0000/0/00,00 00 00
CE Log ErrCode=43  LBA=252b1842  Type=4  Remove from Pending 252b1842
(S)SATA Reset
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0009
ATA St 51 Er 04 Op a1 a,0000/0/00,00 00 00
Niwot:  97f29ff7  b6  97f29ff7.1.840 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b1843  Type=4  Remove from Pending 252b1843
AT Er 01 Nwt Er 43 RdWr 1d36d.01.000b
Niwot:  9ff79ff7  b6  9ff79ff7.1.840 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.000b
CE Log ErrCode=43  LBA=252b1845  Type=5  Add To Pending 252b1845
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0010
CE Log ErrCode=43  LBA=252b184a  Type=4  Remove from Pending 252b184a
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0011
CE Log ErrCode=43  LBA=252b184b  Type=4  Remove from Pending 252b184b
(H)SATA Reset
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0012
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
DiskAccess ReadSector EC=43 at 01d36d.01.0012
CE Log ErrCode=43  LBA=252b184c  Type=5  Add To Pending 252b184c
(S)SATA Reset
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0013
CE Log ErrCode=43  LBA=252b184d  Type=4  Remove from Pending 252b184d
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0014
CE Log ErrCode=43  LBA=252b184e  Type=4  Remove from Pending 252b184e
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0018
CE Log ErrCode=43  LBA=252b1852  Type=4  Remove from Pending 252b1852
AT Er 01 Nwt Er 43 RdWr 1d36d.01.001c
CE Log ErrCode=43  LBA=252b1856  Type=4  Remove from Pending 252b1856
AT Er 01 Nwt Er 43 RdWr 1d36d.01.001d
CE Log ErrCode=43  LBA=252b1857  Type=4  Remove from Pending 252b1857
AT Er 01 Nwt Er 43 RdWr 1d36d.01.001e
DiskAccess ReadSector EC=43 at 01d36d.01.001e
CE Log ErrCode=43  LBA=252b1858  Type=5  Add To Pending 252b1858
(S)SATA Reset
AT Er 01 Nwt Er 43 RdWr 1d36d.01.001f
CE Log ErrCode=43  LBA=252b1859  Type=4  Remove from Pending 252b1859
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0022
DiskAccess ReadSector EC=43 at 01d36d.01.0022
CE Log ErrCode=43  LBA=252b185c  Type=5  Add To Pending 252b185c
AT Er 01 Nwt Er 43 RdWr 1d36d.01.002c
CE Log ErrCode=43  LBA=252b1866  Type=4  Remove from Pending 252b1866
AT Er 01 Nwt Er 43 RdWr 1d36d.01.002e
CE Log ErrCode=43  LBA=252b1868  Type=4  Remove from Pending 252b1868
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0031
CE Log ErrCode=43  LBA=252b186b  Type=4  Remove from Pending 252b186b
AT Er 01 Nwt Er 43 RdWr 1d36d.01.003d
CE Log ErrCode=43  LBA=252b1877  Type=4  Remove from Pending 252b1877
(S)SATA Reset
AT Er 01 Nwt Er 43 RdWr 1d36d.01.003e
DiskAccess ReadSector EC=43 at 01d36d.01.003e
CE Log ErrCode=43  LBA=252b1878  Type=5  Add To Pending 252b1878
AT Er 01 Nwt Er 48 RdWr 1d36d.01.0044
DiskAccess ReadSector EC=43 at 01d36d.01.0044
CE Log ErrCode=48  LBA=252b187e  Type=5  Add To Pending 252b187e
AT Er 01 Nwt Er 43 RdWr 1d36d.01.004d
DiskAccess ReadSector EC=43 at 01d36d.01.004d
CE Log ErrCode=43  LBA=252b1887  Type=5  Add To Pending 252b1887
AT Er 01 Nwt Er 43 RdWr 1d36d.01.004e
CE Log ErrCode=43  LBA=252b1888  Type=4  Remove from Pending 252b1888
AT Er 00 Nwt Er 43 RdWr 1d36d.01.004f
Niwot:  97f29ff7  b6  97f29ff7.1.842 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b1889  Type=4  Remove from Pending 252b1889
AT Er 00 Nwt Er 49 RdWr 1d36d.01.0050
Niwot:  9ff79ff7  b6  9ff79ff7.1.842 0000  005f 0000 00c5
CE Log ErrCode=49  LBA=252b188a  Type=4  Remove from Pending 252b188a
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0055
CE Log ErrCode=43  LBA=252b188f  Type=4  Remove from Pending 252b188f
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0056
CE Log ErrCode=43  LBA=252b1890  Type=4  Remove from Pending 252b1890
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0057
DiskAccess ReadSector EC=43 at 01d36d.01.0057
CE Log ErrCode=43  LBA=252b1891  Type=5  Add To Pending 252b1891
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0058
ATA St d0 Er 00 Op 25 e,  0000000,0100 0100 0000
Niwot:  97f29ff7  b6  97f29ff7.1.849 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b1892  Type=4  Remove from Pending 252b1892
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0060
Niwot:  9ff79ff7  b6  9ff79ff7.1.849 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.0060
CE Log ErrCode=43  LBA=252b189a  Type=5  Add To Pending 252b189a
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0066
CE Log ErrCode=43  LBA=252b18a0  Type=4  Remove from Pending 252b18a0
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0067
Niwot:  97f29ff7  b6  97f29ff7.1.850 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18a1  Type=4  Remove from Pending 252b18a1
AT Er 00 Nwt Er 43 RdWr 1d36d.01.006e
Niwot:  9ff79ff7  b6  9ff79ff7.1.850 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18a8  Type=4  Remove from Pending 252b18a8
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0071
DiskAccess ReadSector EC=43 at 01d36d.01.0071
CE Log ErrCode=43  LBA=252b18ab  Type=5  Add To Pending 252b18ab
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0072
Niwot:  97f29ff7  b6  97f29ff7.1.857 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18ac  Type=4  Remove from Pending 252b18ac
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0095
Niwot:  9ff79ff7  b6  9ff79ff7.1.857 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18cf  Type=4  Remove from Pending 252b18cf
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0096
Niwot:  97f29ff7  b6  97f29ff7.1.85e 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18d0  Type=4  Remove from Pending 252b18d0
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0099
Niwot:  9ff79ff7  b6  9ff79ff7.1.85e 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18d3  Type=4  Remove from Pending 252b18d3
AT Er 00 Nwt Er 43 RdWr 1d36d.01.009d
CE Log ErrCode=43  LBA=252b18d7  Type=4  Remove from Pending 252b18d7
AT Er 00 Nwt Er 43 RdWr 1d36d.01.009e
Niwot:  97f29ff7  b6  97f29ff7.1.865 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18d8  Type=4  Remove from Pending 252b18d8
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00a0
Niwot:  9ff79ff7  b6  9ff79ff7.1.865 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18da  Type=4  Remove from Pending 252b18da
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00a9
DiskAccess ReadSector EC=43 at 01d36d.01.00a9
CE Log ErrCode=43  LBA=252b18e3  Type=5  Add To Pending 252b18e3
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00aa
Niwot:  97f29ff7  b6  97f29ff7.1.86c 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18e4  Type=4  Remove from Pending 252b18e4
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00ad
Niwot:  9ff79ff7  b6  9ff79ff7.1.86c 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.00ad
CE Log ErrCode=43  LBA=252b18e7  Type=5  Add To Pending 252b18e7
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00b0
DiskAccess ReadSector EC=43 at 01d36d.01.00b0
CE Log ErrCode=43  LBA=252b18ea  Type=5  Add To Pending 252b18ea
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00b1
Niwot:  97f29ff7  b6  97f29ff7.1.873 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18eb  Type=4  Remove from Pending 252b18eb
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00b2
Niwot:  9ff79ff7  b6  9ff79ff7.1.873 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.00b2
CE Log ErrCode=43  LBA=252b18ec  Type=5  Add To Pending 252b18ec
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00b5
CE Log ErrCode=43  LBA=252b18ef  Type=4  Remove from Pending 252b18ef
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00b7
ATA St d0 Er 00 Op 25 e,  0000007,0400 0400 0000
Niwot:  97f29ff7  b6  97f29ff7.1.87a 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.00b7
CE Log ErrCode=43  LBA=252b18f1  Type=5  Add To Pending 252b18f1
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00b8
Niwot:  9ff79ff7  b6  9ff79ff7.1.87a 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.00b8
CE Log ErrCode=43  LBA=252b18f2  Type=5  Add To Pending 252b18f2
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00b9
ATA St d0 Er 00 Op 25 e,  0000002,0100 0100 0000
Niwot:  97f29ff7  b6  97f29ff7.1.88f 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18f3  Type=4  Remove from Pending 252b18f3
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00bf
Niwot:  9ff79ff7  b6  9ff79ff7.1.88f 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18f9  Type=4  Remove from Pending 252b18f9
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00c0
DiskAccess ReadSector EC=43 at 01d36d.01.00c0
CE Log ErrCode=43  LBA=252b18fa  Type=5  Add To Pending 252b18fa
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00c1
ATA St d0 Er 00 Op 25 e,  000003f,1000 1000 0000
Niwot:  97f29ff7  b6  97f29ff7.1.898 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b18fb  Type=4  Remove from Pending 252b18fb
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00c2
Niwot:  9ff79ff7  b6  9ff79ff7.1.898 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.00c2
CE Log ErrCode=43  LBA=252b18fc  Type=5  Add To Pending 252b18fc
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00c5
CE Log ErrCode=43  LBA=252b18ff  Type=4  Remove from Pending 252b18ff
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00c6
ATA St d0 Er 00 Op 25 e,  000003f,2000 2000 0000
Niwot:  97f29ff7  b6  97f29ff7.1.90d 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b1900  Type=4  Remove from Pending 252b1900
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00c7
Niwot:  9ff79ff7  b6  9ff79ff7.1.90d 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.00c7
CE Log ErrCode=43  LBA=252b1901  Type=5  Add To Pending 252b1901
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00c8
DiskAccess ReadSector EC=43 at 01d36d.01.00c8
CE Log ErrCode=43  LBA=252b1902  Type=5  Add To Pending 252b1902
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00c9
ATA St d0 Er 00 Op 25 e,  000003f,0100 0100 0000
Niwot:  97f29ff7  b6  97f29ff7.1.99e 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b1903  Type=4  Remove from Pending 252b1903
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00ca
Niwot:  9ff79ff7  b6  9ff79ff7.1.99e 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.00ca
CE Log ErrCode=43  LBA=252b1904  Type=5  Add To Pending 252b1904
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00cb
CE Log ErrCode=43  LBA=252b1905  Type=4  Remove from Pending 252b1905
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00cc
ATA St d0 Er 00 Op 25 e,  0065b1f,8000 8000 0000
Niwot:  97f29ff7  b6  97f29ff7.1.9e4 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.00cc
CE Log ErrCode=43  LBA=252b1906  Type=5  Add To Pending 252b1906
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00cd
Niwot:  9ff79ff7  b6  9ff79ff7.1.9e4 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.00cd
CE Log ErrCode=43  LBA=252b1907  Type=5  Add To Pending 252b1907
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00cf
ATA St d0 Er 00 Op 25 e,  1723867f,2000 2000 0000
Niwot:  97f29ff7  b6  97f29ff7.1.b0e 0000  005f 0000 1000
CE Log ErrCode=43  LBA=252b1909  Type=4  Remove from Pending 252b1909
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00d0
Niwot:  9ff79ff7  b6  9ff79ff7.1.b0e 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00d0
CE Log ErrCode=43  LBA=252b190a  Type=5  Add To Pending 252b190a
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00d1
DiskAccess ReadSector EC=43 at 01d36d.01.00d1
CE Log ErrCode=43  LBA=252b190b  Type=5  Add To Pending 252b190b
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00d3
ATA St d0 Er 00 Op 25 e,  000003f,0800 0800 0000
Niwot:  97f29ff7  b6  97f29ff7.1.cf7 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00d3
CE Log ErrCode=43  LBA=252b190d  Type=5  Add To Pending 252b190d
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00d4
Niwot:  9ff79ff7  b6  9ff79ff7.1.cf7 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00d4
CE Log ErrCode=43  LBA=252b190e  Type=5  Add To Pending 252b190e
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00d6
ATA St d0 Er 00 Op 25 e,  17a9627f,2000 2000 0000
Niwot:  97f29ff7  b6  97f29ff7.1.d51 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00d6
CE Log ErrCode=43  LBA=252b1910  Type=5  Add To Pending 252b1910
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00d7
Niwot:  9ff79ff7  b6  9ff79ff7.1.d51 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00d7
CE Log ErrCode=43  LBA=252b1911  Type=5  Add To Pending 252b1911
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00d9
Niwot:  97f29ff7  b6  97f29ff7.1.d8c 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00d9
CE Log ErrCode=43  LBA=252b1913  Type=5  Add To Pending 252b1913
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00da
Niwot:  9ff79ff7  b6  9ff79ff7.1.d8c 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00da
CE Log ErrCode=43  LBA=252b1914  Type=5  Add Tï¹¥¹252b1914
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00db
ATA St d0 Er 00 Op 25 e,  172b377f,2000 2000 0000
Niwot:  97f29ff7  b6  97f29ff7.1.dd2 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00db
CE Log ErrCode=43  LBA=252b1915  Type=5  Add To Pending 252b1915
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00df
Niwot:  9ff79ff7  b6  9ff79ff7.1.dd2 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00df
CE Log ErrCode=43  LBA=252b1919  Type=5  Add To Pending 252b1919
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00e0
ATA St d0 Er 00 Op 25 e,  000007f,0400 0400 0000
Niwot:  97f29ff7  b6  97f29ff7.1.e06 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00e0
CE Log ErrCode=43  LBA=252b191a  Type=5  Add To Pending 252b191a
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00e1
Niwot:  9ff79ff7  b6  9ff79ff7.1.e06 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00e1
CE Log ErrCode=43  LBA=252b191b  Type=5  Add To Pending 252b191b
AT Er 00 Nwt Er 43 RdWr 1d36d.01.00e4
ATA St d0 Er 00 Op 25 e,  182c64bf,2000 2000 0000
Niwot:  97f29ff7  b6  97f29ff7.1.e92 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00e4
CE Log ErrCode=43  LBA=252b191e  Type=5  Add To Pending 252b191e
AT Er 00 Nwt Er 37 RdWr 1d36d.01.00e5
Niwot:  9ff79ff7  b6  9ff79ff7.1.e92 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00e5
CE Log ErrCode=37  LBA=252b191f  Type=5  Add To Pending 252b191f
AT Er 00 Nwt Er 37 RdWr 1d36d.01.00ed
DiskAccess ReadSector EC=43 at 01d36d.01.00ed
CE Log ErrCode=37  LBA=252b1927  Type=5  Add To Pending 252b1927
AT Er 00 Nwt Er 37 RdWr 1d36d.01.00f9
ATA St d0 Er 00 Op 25 e,  18f1ba5f,2000 2000 0000
Niwot:  97f29ff7  b6  97f29ff7.2.0e7 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00f9
CE Log ErrCode=37  LBA=252b1933  Type=5  Add To Pending 252b1933
AT Er 00 Nwt Er 37 RdWr 1d36d.01.00fc
Niwot:  9ff79ff7  b6  9ff79ff7.2.0e7 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.00fc
CE Log ErrCode=37  LBA=252b1936  Type=5  Add To Pending 252b1936
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0114
DiskAccess ReadSector EC=43 at 01d36d.01.0114
CE Log ErrCode=43  LBA=252b194e  Type=5  Add To Pending 252b194e
AT Er 00 Nwt Er 43 RdWr 115c0.01.0100
ATA St d0 Er 00 Op 25 e,  18f1ba5f,2000 1f00 0000
Niwot:  18f1ba5f  3a  18f1ba5f.1.fd0 8000  20e9 0800 0000
CE Log ErrCode=43  LBA=18f1ba68  Type=6Not handled software path:
Reset
4096k x 16 DRAM
Buzz HM SFI
(P)SATA Reset
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0003
CE Log ErrCode=43  LBA=252b183d  Type=4  Remove from Pending 252b183d
(S)SATA Reset
AT Er 00 Nwt Er 43 RdWr 1d36d.01.000b
(S)SATA Reset
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0044
CE Log ErrCode=43  LBA=252b187e  Type=5  Add To Pending 252b187e
(S)SATA Reset
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0046
CE Log ErrCode=43  LBA=252b1880  Type=4  Remove from Pending 252b1880
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0057
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0060
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0071
(S)SATA Reset
AT Er 01 Nwt Er 43 RdWr 1d36d.01.0072
AT Er 01 Nwt Er 43 RdWr 1d36d.01.00a9
AT Er 01 Nwt Er 43 RdWr 1d36d.01.00ad
AT Er 01 Nwt Er 43 RdWr 1d36d.01.00b0
AT Er 01 Nwt Er 43 RdWr 1d36d.01.00b2
CE Log ErrCode=43  LBA=252b18ec  Type=4  Remove from Pending 252b18ec
(S)SATA Reset
AT Er 01 Nwt Er 43 RdWr 1d36d.01.00b4
CE Log ErrCode=43  LBA=252b18ee  Type=4  Remove from Pending 252b18ee
AT Er 01 Nwt Er 43 RdWr 1d36d.01.00b8
AT Er 01 Nwt Er 43 RdWr 1d36d.01.00c0
AT Er 01 Nwt Er 43 RdWr 1d36d.01.00c2
AT Er 01 Nwt Er 43 RdWr 1d36d.01.00c7
Niwot:  97f29ff7  b6  97f29ff7.1.84b 0000  005f 0000 00c5
Niwot:  9ff79ff7  b6  9ff79ff7.1.84b 0000  005f 0000 00c5
Niwot:  97f29ff7  b6  97f29ff7.1.852 0000  005f 0000 00c5
Niwot:  9ff79ff7  b6  9ff79ff7.1.852 0000  005f 0000 00c5
Niwot:  97f29ff7  b6  97f29ff7.1.859 0000  005f 0000 00c5
Niwot:  9ff79ff7  b6  9ff79ff7.1.859 0000  005f 0000 00c5
Niwot:  97f29ff7  b6  97f29ff7.1.860 0000  005f 0000 00c5
Niwot:  9ff79ff7  b6  9ff79ff7.1.860 0000  005f 0000 00c5
CE Log ErrCode=43  LBA=252b1914  Type=4  Remove from Pending 252b1914
Niwot:  97f29ff7  b6  97f29ff7.1.867 0000  005f 0000 00c5
Niwot:  9ff79ff7  b6  9ff79ff7.1.867 0000  005f 0000 00c5
Niwot:  97f29ff7  b6  97f29ff7.1.86e 0000  005f 0000 00c5
Niwot:  9ff79ff7  b6  9ff79ff7.1.86e 0000  005f 0000 00c5
Niwot:  97f29ff7  b6  97f29ff7.1.875 0000  005f 0000 00c5
Niwot:  9ff79ff7  b6  9ff79ff7.1.875 0000  005f 0000 00c5
Niwot:  97f29ff7  b6  97f29ff7.1.87c 0000  005f 0000 00c5
Niwot:  9ff79ff7  b6  9ff79ff7.1.87c 0000  005f 0000 00c5
Niwot:  97f29ff7  b6  97f29ff7.1.891 0000  005f 0000 00c5
AT Er 00 Nwt Er 37 RdWr 1d36d.01.011d
Niwot:  9ff79ff7  b6  9ff79ff7.1.891 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.011d
CE Log ErrCode=37  LBA=252b1957  Type=5  Add To Pending 252b1957
AT Er 00 Nwt Er 37 RdWr 1d36d.01.012b
Niwot:  97f29ff7  b6  97f29ff7.1.899 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.012b
CE Log ErrCode=37  LBA=252b1965  Type=5  Add To Pending 252b1965
AT Er 00 Nwt Er 37 RdWr 1d36d.01.0132
Niwot:  9ff79ff7  b6  9ff79ff7.1.899 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.0132
CE Log ErrCode=37  LBA=252b196c  Type=5  Add To Pending 252b196c
AT Er 00 Nwt Er 37 RdWr 1d36d.01.0135
DiskAccess ReadSector EC=43 at 01d36d.01.0135
CE Log ErrCode=37  LBA=252b196f  Type=5  Add To Pending 252b196f
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0138
Niwot:  97f29ff7  b6  97f29ff7.1.90e 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.0138
CE Log ErrCode=43  LBA=252b1972  Type=5  Add To Pending 252b1972
AT Er 00 Nwt Er 37 RdWr 1d36d.01.013a
Niwot:  9ff79ff7  b6  9ff79ff7.1.90e 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.013a
CE Log ErrCode=37  LBA=252b1974  Type=5  Add To Pending 252b1974
AT Er 00 Nwt Er 37 RdWr 1d36d.01.013b
DiskAccess ReadSector EC=43 at 01d36d.01.013b
CE Log ErrCode=37  LBA=252b1975  Type=5  Add To Pending 252b1975
AT Er 00 Nwt Er 43 RdWr 1d36d.01.013c
Niwot:  97f29ff7  b6  97f29ff7.1.954 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.013c
CE Log ErrCode=43  LBA=252b1976  Type=5  Add To Pending 252b1976
AT Er 00 Nwt Er 43 RdWr 1d36d.01.013f
Niwot:  9ff79ff7  b6  9ff79ff7.1.954 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.013f
CE Log ErrCode=43  LBA=252b1979  Type=5  Add To Pending 252b1979
AT Er 00 Nwt Er 37 RdWr 1d36d.01.0141
DiskAccess ReadSector EC=43 at 01d36d.01.0141
CE Log ErrCode=37  LBA=252b197b  Type=5  Add To Pending 252b197b
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0143
Niwot:  97f29ff7  b6  97f29ff7.1.9eb 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.0143
CE Log ErrCode=43  LBA=252b197d  Type=5  Add To Pending 252b197d
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0144
Niwot:  9ff79ff7  b6  9ff79ff7.1.9eb 0000  005f 0000 00c5
DiskAccess ReadSector EC=43 at 01d36d.01.0144
CE Log ErrCode=43  LBA=252b197e  Type=5  Add To Pending 252b197e
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0146
Niwot:  97f29ff7  b6  97f29ff7.1.b1c 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0146
CE Log ErrCode=43  LBA=252b1980  Type=5  Add To Pending 252b1980
AT Er 00 Nwt Er 43 RdWr 1d36d.01.014a
Niwot:  9ff79ff7  b6  9ff79ff7.1.b1c 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.014a
CE Log ErrCode=43  LBA=252b1984  Type=5  Add To Pending 252b1984
AT Er 00 Nwt Er 43 RdWr 1d36d.01.014b
Niwot:  97f29ff7  b6  97f29ff7.1.b76 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.014b
CE Log ErrCode=43  LBA=252b1985  Type=5  Add To Pending 252b1985
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0152
Niwot:  9ff79ff7  b6  9ff79ff7.1.b76 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0152
CE Log ErrCode=43  LBA=252b198c  Type=5  Add To Pending 252b198c
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0154
DiskAccess ReadSector EC=43 at 01d36d.01.0154
CE Log ErrCode=43  LBA=252b198e  Type=5  Add To Pending 252b198e
AT Er 00 Nwt Er 43 RdWr 1d36d.01.015c
Niwot:  97f29ff7  b6  97f29ff7.1.d5f 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.015c
CE Log ErrCode=43  LBA=252b1996  Type=5  Add To Pending 252b1996
AT Er 00 Nwt Er 37 RdWr 1d36d.01.015d
Niwot:  9ff79ff7  b6  9ff79ff7.1.d5f 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.015d
CE Log ErrCode=37  LBA=252b1997  Type=5  Add To Pending 252b1997
AT Er 00 Nwt Er 43 RdWr 1d36d.01.015e
DiskAccess ReadSector EC=43 at 01d36d.01.015e
CE Log ErrCode=43  LBA=252b1998  Type=5  Add To Pending 252b1998
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0162
Niwot:  97f29ff7  b6  97f29ff7.1.da5 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0162
CE Log ErrCode=43  LBA=252b199c  Type=5  Add To Pending 252b199c
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0163
Niwot:  9ff79ff7  b6  9ff79ff7.1.da5 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0163
CE Log ErrCode=43  LBA=252b199d  Type=5  Add To Pending 252b199d
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0164
Niwot:  97f29ff7  b6  97f29ff7.1.dc8 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0164
CE Log ErrCode=43  LBA=252b199e  Type=5  Add To Pending 252b199e
AT Er 00 Nwt Er 43 RdWr 1d36d.01.016a
Niwot:  9ff79ff7  b6  9ff79ff7.1.dc8 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.016a
CE Log ErrCode=43  LBA=252b19a4  Type=5  Add To Pending 252b19a4
AT Er 00 Nwt Er 43 RdWr 1d36d.01.016d
Niwot:  97f29ff7  b6  97f29ff7.1.e58 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.016d
CE Log ErrCode=43  LBA=252b19a7  Type=5  Add To Pending 252b19a7
AT Er 00 Nwt Er 43 RdWr 1d36d.01.016e
Niwot:  9ff79ff7  b6  9ff79ff7.1.e58 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.016e
CE Log ErrCode=43  LBA=252b19a8  Type=5  Add To Pending 252b19a8
AT Er 00 Nwt Er 47 RdWr 1d36d.01.0170
Niwot:  97f29ff7  b6  97f29ff7.1.e8a 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0170
CE Log ErrCode=47  LBA=252b19aa  Type=5  Add To Pending 252b19aa
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0171
Niwot:  9ff79ff7  b6  9ff79ff7.1.e8a 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0171
CE Log ErrCode=43  LBA=252b19ab  Type=5  Add To Pending 252b19ab
AT Er 00 Nwt Er 37 RdWr 1d36d.01.0175
Niwot:  97f29ff7  b6  97f29ff7.2.1ad 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0175
CE Log ErrCode=37  LBA=252b19af  Type=5  Add To Pending 252b19af
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0176
Niwot:  9ff79ff7  b6  9ff79ff7.2.1ad 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0176
CE Log ErrCode=43  LBA=252b19b0  Type=5  Add To Pending 252b19b0
AT Er 00 Nwt Er 43 RdWr 1d36d.01.0177
Niwot:  97f29ff7  b6  97f29ff7.2.1f3 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.0177
CE Log ErrCode=43  LBA=252b19b1  Type=5  Add To Pending 252b19b1
AT Er 00 Nwt Er 37 RdWr 1d36d.01.017a
Niwot:  9ff79ff7  b6  9ff79ff7.2.1f3 0000  005f 0000 1000
DiskAccess ReadSector EC=43 at 01d36d.01.017a
CE Log ErrCode=37  LBA=252b19b4  Type=5  Add To Pending 252b19b4
AT Er 00 Nwt Er 43 RdWr 115c0.01.00f8
Niwot:  18f1ba5f  3a  18f1ba5f.1.dd0 8000  21f5 0800 0000
CE Log ErrCode=43  LBA=18f1ba60  Type=6Not handled software path:
 Post subject: Re: Seagate 7200.10 ST3320820AS 320GB
PostPosted: June 23rd, 2014, 4:34
Greetings and good morning, sir.
If the data on the drive is not of critical importance and lacking better tools you can try this out :
http://malthus.zapto.org/viewtopic.php?f=83&t=175
PostPosted: June 23rd, 2014, 4:39
And just as a side note, SATA-USB adaptors are NOT the ideal way of attempting data recovery as well...
PostPosted: June 23rd, 2014, 4:44
T4E commands should work, but use it only if ROM version match CERT code.
To see if rom match cert code press CTRL+R to load cert, then post here what does it show.
Don't give T4E command if rom and cert have different version.
Of course, the best way to recover data on this drive is via loader, because T4E can be danger.
If T4E command is your only choice then i suggest you first to backup the firmware with programs as Sediv or STcom
My firmware database:
PostPosted: June 23rd, 2014, 4:50
Thank you Madoka, That's very helpful. And warning noted. This drive owner assured me there are backups, and basically this is for my own interest...
I will have a read of the Oracle post and as it is a "Bin it" drive will probably try it out tomorrow.
If there was Data Recovery needed I would have contacted others on here that do Hard disks.
PostPosted: June 23rd, 2014, 22:12
Well, I think i have kind of bricked the drive.
I did the commands, the cert matched.
and now the drive detects in DMDE but if it actually reads the drive, all Sectors show 00000.
Terminal is similar to before, though if I try DMDE when the drive is booting, there is some resemblence of a partitioning still available.
still get a similar output.
---cut---
(S)SATA Reset
AT Er 00 Nwt Er 47 RdWr 00018.00.0009
ATA St d0 Er 00 Op 25 e,  0000007,0400 0300 0000
Niwot:  00000000  18  00000000.1.890 8000  1840 0800 0000
DiskAccess ReadSector EC=47 at 000018.00.0009
CE Log ErrCode=47  LBA=9  Type=5  Add To Pending 9
NiwotErrorLBA 00000009
AT Er 00 Nwt Er 47 RdWr ffffffff.00.00e7
ATA St d1 Er 10 Op 25 e,  0000007,0400 0000 0000
Niwot:  00016152  58  00016152.0.0e6 0001  3fe0 0001 0000
(S)SATA Reset
AT Er 00 Nwt Er 47 RdWr 00018.00.0000
ATA St d0 Er 00 Op 25 e,  0000000,0100 0000 0000
CE Log ErrCode=47  LBA=0  Type=6Not handled software path:
End of the line?
PostPosted: June 27th, 2014, 0:20
Can someone say if I should continue with this one? It definitely wont be going to any Pro DR Shop, but as it is still kind of responding, for my own interests Id like to see if I can get it working enough to read the FS.
Cheers
