 Post subject: SEAGATE 7200.7 CANNOT SS
PostPosted: June 29th, 2014, 14:27
T>(AutoRd Err 47 at 00ecf4.00.0000
INVALID Cert Disk Code - ROM Resident Revision Required: 3.04
Command Inactive - No VALID Cert Code Detecte
T>
IM USING ST COM WHEN START SS THERE IS ERROR CODE
PLEASE ...GIVE ME KNOW HOW TO FIX
 Post subject: Re: SEAGATE 7200.7 CANNOT SS
PostPosted: July 2nd, 2014, 6:32
T>
no body can't help me....?
PostPosted: July 2nd, 2014, 7:32
Greetings !
You will need to load to the drive CERT tracks that are compatible with the ROM code.
Is the PCB native ? Did you mess the CERT on the drive by writting to it with stcom ?
PostPosted: July 5th, 2014, 11:47
Madoka wrote:
Greetings !
yes the pcb is native, and i load the cert tracks with backup cert when i start the selfscan before...
dont know what is wrong all i do is
first back up the app,cert,vendor ect with stcom
then i start ss
after finish
that what show in terminal log
