 Post subject: Problem with headstack change on Fujitsu 2.5''harddrive
PostPosted: August 2nd, 2014, 8:05
Dear all,
this is my very first post there!
My problem it's that i friend of mine got a problem with his harddisk.
Basically there is no way to read into this one...After few check (we have already mark this hard drive as "dead") I have decided
to change the headstack.
All the process look go pretty straight forward, without any problem to unload the old headstack and mount the new one.
But on computer idle i have the following strange stuff of the headstack:
https://www.youtube.com/watch?v=mdTduVF ... e=youtu.be
Have you any idea of what could be? It's possibile that the headstack can't pick the parking zone?
Let me know.
Other hd info are:
Fujitsu 100GB 2.5'' hard drive IDE
Model MHV2100AT PL
Let me know.
Thank's in advance.
p.s. The harddrive not contain enterprise data, so is not plausbile spent few 1000/2000$ with a specialized company in order to bring the data back:-)
 Post subject: Re: Problem with headstack change on Fujitsu 2.5''harddrive
PostPosted: August 2nd, 2014, 8:47
Looks like one of the heads might be damaged preventing the drive from reading the drive information. The head stack might need to be replaced, but there could be other problems too.
Shane
PostPosted: August 2nd, 2014, 11:32
It was not a good idea to open the drive without a proper diagnosis.
I just repaired a Fujitsu drive MHS2020AT that was clicking a lot as your drive, problem was a firmware issue.
The drive clicked for about 5 minutes since power on, then it was detect but very very slowly.
To fix it i did translator regeneration in pc3000 and repaired bad FA + WE mods, now it's detect right away when i power on and with good speed.
What i want to say is it could be possible that you will not solve the problem by changing heads, however heads swap have to be done in clean environment.
Non è stata una buona idea quella di aprire l'unità, senza una corretta diagnosi.
Ho appena riparato un Fujitsu MHS2020AT che aveva le testine che ticchettavano tanto come le tue, si trattava di un problema di firmware.
L'hdd cliccava per circa 5 minuti dall'accensione, dopodichè veniva rilevato ma molto molto lentamente.
Per risolvere il problema ho fatto la rigenerazione dei translators in PC3000 e riparato i moduli firmware FA + WE corrotti, ora quando lo accendo viene rilevato immediatamente senza ticchettii e con una buona velocità di lettura.
Quello che voglio dire è che potrebbe essere possibile che il problema del tuo hdd non si risolva con la sostituzione delle testine se si trattasse di un danno al firmware, tra l'altro le testine andrebbero sostituite in un ambiente sterile (cappa laminare).
My firmware database:
PostPosted: August 3rd, 2014, 4:37
Any advise in order to do that and how to re-flash of The firmware?
Thank's
PostPosted: August 3rd, 2014, 5:36
Hello elbario,
if you don't have propper knowledge and tools it Will be hard to do anything.
Contact michael chiklis, I think he is from Verona and not far away from you
PostPosted: August 3rd, 2014, 6:36
Problem is that he already opened the drive, also it has been powered on it without the cover. :?
Can't work on firmware without proper tools as PC3000 or HD Doctor, this tools are expensive
