 Post subject: Can I recover this harddisk?
PostPosted: July 19th, 2014, 13:06
Model of HDD: Seagate ST9500420AS 750GB SATA
Serial conection mode: UART over Arduino UNO + SATA Power Supply
When accessed via Putty via Arduino getted message and pressed CTRL+Z
(P) SATA Reset
RAW OFF
PASS
APM disabled by SPort
ASCII Diag mode
F3 T>
When entered "m0,2,2,0,0,0,0,22" command getted message:
F3 T>m0,2,2,0,0,0,0,22
BoxPadding Count[ Upper:00000003 Lower:00000003 Left:00000001 Right:00000004]
BoxPadding Debug OFF
Max Wr Retries = 00, Max Rd Retries = 00,  Max Iterations = 00, Max Certify Rewrite Retries = 0000
Ev LBA/Soft XferLen  Zn Trk      Hd Sct  Wdg  PBA      ErrCode
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Total capacity B05E22E PBAs. Total spares left 8833C PBAs [+3.01E-1%].
F3 T>
My questions: Can I recover this device?
Can other command solve anything?
The HDD on question power ONs nicely, getting a click sometimes. Windows not recognizeing it over usb. One netbook recognized it over BIOS, but can't format it. Linux recognize it but very slow making partitions.
I wait answers. Thanks
 Post subject: Re: Can I recover this harddisk?
PostPosted: July 20th, 2014, 3:30
If you are trying to recover important data from this drive, then do not type commands without knowing the problem with the drive or understanding what these command does.
Try connecting the drive directly to a SATA port of any desktop motherboard and check if it detects properly(model and capacity) in its BIOS.
Try to check the drive using MHDD.
USB caddy is not a proper way to check the drive.
DIY has its risks, so do not attempt it on drive with critical data
PostPosted: July 20th, 2014, 12:46
Sathyan is right!
Also, command "m0,2,2,0,0,0,0,22" could have made things worse :(
My firmware database:
PostPosted: July 22nd, 2014, 4:41
Bienvenido klaustro.
Lo primero de todo: Gora San Fermin!
Lo mas importante es hacer un buen diagnostico; no debes de introducir comando vía puerto serie si o sabes cual es el problema y que es lo que hace cada comando.
Esto es muy importante por que puedes hacer mas compleja la situación, llegando al punto de ser irrecuperable el disco si se introducen comandos inadecuados.
Para comenzar es importante que nos indique todos los datos posibles sobre el disco duro:
Marca modelo, P/N, FW, etc
si puede adjunte fotos del disco por ambas caras asi como fotos de la Placa electrónica del disco por ambas caras también.
si lo desea pruebe a enchufar el disco sin adaptador USB, es decir directamente a un adaptador SATA, e indiquemos lo que aparece en la BIOS de su PC
también indique comportamientos del disco, el motor se enciende, el disco hace ruidos entraños, etc.
todo esto es muy importante y ayuda a entender el problema.
I recuerda que si tus datos son importantes lo mejor de todo es contactar con un profesional. si lo deseas indicalo aqui y tendrás varias ofertas personalizadas.
PostPosted: July 22nd, 2014, 4:45
Welcome [b] klaustro [/ b].
First of all: gretings!!
The most important thing is to make a good diagnosis; you must not enter commands via serial interface if you do not know what the problem is and what each command does.
This is very important because it can make the situation more complex, to the point of being unrecoverable disk if improper commands are entered.
To begin it is important to tell us all possible data about the HDD:
Brand model, P / N, FW, etc.
if you can attach pics about the drive (both sides as well) and pics about electronic board from both sides as well.
you can plug the drive without USB adapter, directly to a SATA adapter, and indicate us what is in the BIOS from your PC
also indicate disk behaviors, the engine is started, the drive makes noises etc..
this is very important and helps to understand the problem.
and remember if your data is important the best thing is to contact to a local pro. if you wish please indicate here, and you'll have some personalized quotations.
PostPosted: July 26th, 2014, 1:45
Intentaré prepararte toda la info que me pides lo antes que pueda. En cuanto pille un rato, un saludo!
Gora San Fermin!!
PostPosted: July 26th, 2014, 2:12
1º de todo:
Creo que introduje algún comando que no debía. Lo conectaré de nuevo a Arduino esta próxima semana para detallar lo que cambie exactamente. Para ver si es necesario corregir algo.
2º: Todos los datos posibles del HDD:
Marca: Seagate
Modelo: Momentus ST9750420AS
Capacidad: 750GB
PN: 9RT14G-285
FW: 0002SDM1
3º: Fotos del disco duro:
Esta misma mañana escaneo el disco y la placa electrónica y adjunto las imágenes.
4º: Enchufar el disco SIN adaptador USB (directo al SATA de la placa), BIOS?
Cuando lo enchufo con adaptador USB, la bios no reconoce el disco, pero Linux sí. En cambio si lo conecto a un ordenador portátil que tengo (directo a SATA), en la bios aparece el disco etiquetado como "ST9750420AS".
5º: Comportamientos del disco:
El motor funciona.
Lo que he apreciado es que, una vez que el disco esta conectado a SATA y alimentado, cada X tiempo se oye un "clack" ligero y parece que el motor se para y a los pocos segundos vuelve a funcionar. Yo diría que ocurre en espacios largos de tiempo, es decir, que no pasa muy a menudo, pasa pocas veces.
De momento haber si se te ocurre algo con estos datos.
La próxima semana te diré lo que hice mal cuando lo conecté vía UART, por que sale un mensaje que antes no salia. Lo posteo la semana que viene.
Un saludo y muchas gracias por la atención. :wink:
PostPosted: July 26th, 2014, 5:20
3º: Fotos.
· Parte externa:
http://i57.tinypic.com/2e5sbw8.jpg
· Parte interna:
http://i58.tinypic.com/66i6nb.jpg
· Observase que los contactos que unen las dos piezas en un lado están casi quemados:
http://i58.tinypic.com/dpx1rs.jpg
Un saludo!
PostPosted: July 26th, 2014, 5:21
Ya están subidas las fotos. Solo falta que un moderador de el visto bueno del mensaje y será publicado.
PostPosted: August 6th, 2014, 4:34
Puedes probar a limpiar los contactos sucios, a ver si mejora la situacion. aunque no creo.
Si esto no te soluciona el problema, puede ser devido a cabezas en mal estado o a problemas de superficie de los platos (causa mas probable), tambien puede ser un problema FW.
iNDICAME LOS COMANDOS QUE HAS INTRODUCIDO HASTA AHORA
Solo este: m0,2,2,0,0,0,0,22
