 Post subject: memory card is not formated
PostPosted: August 6th, 2014, 10:39
hi experts can any one please tell me i have sd memory card 8 gb and i want data card is not detect properly how can i recover data ?
 Post subject: Re: memory card is not formated
PostPosted: August 6th, 2014, 11:28
You say not detected properly?
Can you upload pics of the sd card?
Can you access it to read lba using winhex, R-Studio etc?
If you cant get it detected that most likely you will need to use hardware like Soft Center, PC3000 Flash etc.
But this would also depend on if the device is supported. If its a Monolith then you will also need solder skills & the pinout.
Loki
PostPosted: August 6th, 2014, 13:47
May also want to check if it is fake. May be as simple as that.
PostPosted: August 6th, 2014, 18:43
Hi, download DMDE and right click on the devic and take an image of the card. after that use recovery software.
best would be GetDataBack or R-Studio, but can try with free version of Recuva.
If the card is somewhat detected, this should work.
otherwise, if you get I/O error, you will need to take to DR company that does flash.
PostPosted: August 7th, 2014, 6:05
Hi HARD RECOVER
As said here if you can access to secs clone the SD with DMDE, if you can not get access to secs the you need ezpecialized tools
Users browsing this forum: No registered users and 43 guests
