 Post subject: Head replacement help
PostPosted: August 14th, 2014, 8:30
Hey,
not new to data recovery but new to the head replacement part.
i got 2 hdd's one samsung MP0402h and a SG st9320325AS.
now i read alot about how to do it and i even got the tools for it. but i seem to be running into problems.
for donors i use the following matching table
Seagate
Full Model Number. Example: ST9640320AS, ST31000528AS
Site Code. Example: TK, AMK, KRATSG, WUXISG
Full part number or first 3 characters in serial number. Example: 9Y7389-301, 9JU138-302, 5MA84KC2, 9ND29XWG
Full Model Number. Example: HA250JC, HM120JI, SV0602H
Bar Code Side. Example: V6060, P/V FS, T166C
Firmware (could be missing). Example: ZH100-34, HH100-10
After replacing the heads they both still seem to be clicking.
after i place the heads back into there donors the donors work fine, this to me seems that how i replace the heads seems to be correct.
can anyone comfirm that the matching tables i use are correct and maybe have some tips for me.
thanks in advance
 Post subject: Re: Head replacement help
PostPosted: August 14th, 2014, 8:56
tables Looks fine.
Maybe the problem is FW, or bad media
PostPosted: August 14th, 2014, 9:10
Have you tried the patient heads into the donors?
PostPosted: August 14th, 2014, 9:56
the original head was damaged seen by eye. so no i didn't not do that.
hhddrec wrote:
tables Looks fine.
thanks for the info that at least the tables are fine.
PostPosted: August 15th, 2014, 5:53
hhddrec wrote:
tables Looks fine.
If patient heads are badly very probably mediad problemas toó
Can you send pics from badly heads¿
PostPosted: August 21st, 2014, 10:44
The heads could be incompatible.
Esp. for the Seagate drive, your guide misses the most important parameter, esp. for your model.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 47 guests
