 Post subject: ST1000DM003 keeps bsy
PostPosted: June 17th, 2014, 13:06
Hello !
i have this drive for repair ,, no data needed , and i would like to take your professional opinion on it ..
drive behaves normal ..
terminal og is like the following
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:0021
(P) SATA Reset
ASCII Diag mode
F3 T>
no errors if i didn't request the command promt ..
but drive will keep in BSY state ..
any ideas ?
well appreciated
 Post subject: Re: ST1000DM003 keeps bsy
PostPosted: June 17th, 2014, 17:03
formating the drive goes smooth .. latest line are
User Partition Format 98% complete, Zone 1C, Pass 01, LBA 00000E6D5657, ErrCode 00000080, Elapsed Time 115 mins 00 secs S21(01)
User Partition Format 99% complete, Zone 1D, Pass 00, LBA 00000E77E1B3, ErrCode C4090081, Elapsed Time 115 mins 30 secs
User Partition Format 99% complete, Zone 1D, Pass 00, LBA 00000E8246F7, ErrCode C4090081, Elapsed Time 116 mins 00 secs S21(01)
User Partition Format 99% complete, Zone 1D, Pass 00, LBA 00000E8CAA59, ErrCode C4030086, Elapsed Time 116 mins 30 secs
TCC:0026
S21(01)S21(01)
User Partition Format 99% complete, Zone 1D, Pass 00, LBA 00000E970B33, ErrCode C4030086, Elapsed Time 117 mins 00 secs
(DOS) File Save
(DOS) File Save
User Partition Format Successful - Elapsed Time 117 mins 00 secs
heads test are
Head 00 Resistance 0140
Head 01 Resistance 00D2
PostPosted: June 17th, 2014, 17:21
Problem solved :)
thanks for those who helped :wink:
PostPosted: June 18th, 2014, 6:55
HI raven4d!
Can you explain us how you solved this case?
are you used the "one button fix" solution from SD?
are you used commnads to solve this case?
we apreciate your help!
PostPosted: August 26th, 2014, 19:39
Yes, please complete this post with what was done to fix it.
I have one with seemingly same problem,
-Drew
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 50 guests
