 Post subject: WD Head Alignment by Cover Position - last family/model?
PostPosted: September 9th, 2014, 8:43
Can anyone tell me at what point (family/model/date) did Western Digital change the design of their drives so that head alignment is no longer dependent upon the cover position?
I have a WD2500AAKS-22B3A0 drive from 31-Aug-2008 that needs a head swap and I'm reluctant to start if it is one of the models where head alignment is lost as soon as the cover is removed.
 Post subject: Re: WD Head Alignment by Cover Position - last family/model?
PostPosted: September 9th, 2014, 9:11
My guess is Zeus.
The xxxAAKS had wider SA track widths and is not top-cover position dependent.
http://www.datasaversllc.com
PostPosted: September 9th, 2014, 9:31
What he said ^^^^
These don't have the alignment issue.
PostPosted: September 9th, 2014, 10:45
Thanks kindly for your helpfulness. Rather than ask this question each time, is there a reference that would indicate whether the drive is dependent upon cover position? I'll try to find out which families pre-dated/followed Zeus in the meantime.
PostPosted: September 9th, 2014, 11:11
Ah the memories =) Zeus the 4 platter monstrosity. Never did play nice for head swaps with a single donor. Always required a second one to pick up a few heads missing from primary try =) Was it the 1st 500 gb WD on the market ?
PostPosted: September 10th, 2014, 4:54
Indeed. Those don't like it at all when they have their heads changed.
All pre-ROYL drives are cover position sensitive.
PostPosted: September 10th, 2014, 4:59
Yep, nasty things!
I've done a platter swap on one of these too, that was great fun!.... NOT :evil:
PostPosted: September 10th, 2014, 10:53
northwind wrote:
Ah, thanks, Northwind! That's what I was looking for.
PostPosted: September 11th, 2014, 4:01
You're most welcome.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 57 guests
