 Post subject: bitlocked drive with weak heads
PostPosted: September 9th, 2014, 16:46
Hello ,
i would like to take your professional opinion in ths case .
drive is WD10TPVT-00U4RT1
drive was dropped , and it's bitlocked :? .
doing a head map i figured that it has heads as following 0.1.2.3.4.5
head 2 and 4 have issues in the first 65000000 LBAs
other than that drive was imaged ( fully from 65000K till the end and partially from 0 till 65000K 'with H2 and 4 excluded')
when i connected the destination , windows showed bitlocker error ,
squeesing sectors out from the source drive caused the following
drive goes to DRD and DSC , but when trying to identify it stuck at BSY and no further actions can be taken ,
mostly every sector that can be read out of it , was read .
any ideas ? does it worth the time being spent on it ?
thanks
 Post subject: Re: bitlocked drive with weak heads
PostPosted: September 11th, 2014, 5:12
Hi raven4d!
Check out this topic:
viewtopic.php?f=1&t=28442&hilit=wd+busy+solution
Good luck!
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 57 guests
