Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Any Way to recover Translator on WDC WD5000BEVT-22A0RT0?
PostPosted: September 11th, 2014, 7:22
Hi Fran, Thanks for your help
I,ll upload it, but i think this is not the problem, because i tryed to repair manually module and write it, but i can not rewrite it i get error.
PostPosted: September 11th, 2014, 8:36
hhddrec wrote:
I can see that when i try to read service tracks i do not get errors readig.
This means that if you write these tracks to a donor drive, all of the modules are likely to be good. Looks like a smart hot swap donor method is the way to image this drive.
http://www.datasaversllc.com
PostPosted: September 11th, 2014, 9:32
this mean this module place in SA have bad esctors did you try to shift this module to another empty place on Sa
you can do it by dir editor in your pc3k or more easy way by DFl
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: September 11th, 2014, 9:34
hhddrec wrote:
Do you know witch track contains Translator Info (Mod31)??
track 250, but not sure. Check with an Hex editor program first
My firmware database:
PostPosted: September 11th, 2014, 9:37
Thanks to all gurus (Michael, Frank, Tawfeek, Jono, HDD Spaz, MindMergepk)here
Case solved writing tracks
PostPosted: September 11th, 2014, 9:45
Hi tawfeek_mokhtar, good option too, but now solved
PostPosted: September 11th, 2014, 9:50
Solved as you can see on mod directory
PostPosted: September 11th, 2014, 9:54
Very good :lol:
So it was just translator mod corruption, right?
After repairing mod by ABA, did you do fast translator regeneration on p-list?
Last edited by michael chiklis on September 11th, 2014, 9:55, edited 1 time in total.
congratulations :arrow:
Tawfeek Mokhtar
Users browsing this forum: Google [Bot] and 62 guests
