 Post subject: ST9500325AS issue
PostPosted: September 19th, 2014, 4:58
Hello friends ,
i have this drive that will appreciated helping me with .
drive ID ok , and goes to DRDY and DSC but shows 0 capacity , terminal output is
Rst 0x08M
RW cmd 0002 req = 89 3E 00 00 17 02 00 00 00 00 00 00 08 8C 08 00 87 97 09 00 08 8C 08 00
opts = 00001121
RW Err = C3160080
RW cmd 0002 req = 89 3E 00 00 01 00 00 00 00 00 00 00 08 8C 08 00 87 97 09 00 08 8C 08 00
opts = 00001121
RW Err = C3160084
RW cmd 0002 req = 75 5F 02 00 17 02 00 00 00 00 00 00 08 8C 08 00 87 97 09 00 08 8C 08 00
opts = 00001121
RW Err = C3160080
RW cmd 0002 req = 75 5F 02 00 01 00 00 00 00 00 00 00 08 8C 08 00 87 97 09 00 08 8C 08 00
opts = 00001121
RW Err = C3160084
ASCII Diag mode
F3 T>
any chance solving this issue using terminal commands ?
thanks
 Post subject: Re: ST9500325AS issue
PostPosted: September 19th, 2014, 5:21
This is a translator issue.
Did you a head resistance test?
go to level 7 (/7)
Test command= X
PostPosted: September 19th, 2014, 9:17
go to level 7 (/7)
Test command= X
thanks for the advice ,
heads test are
Head 00 Resistance 00FD
Head 01 Resistance 00B3
Head 02 Resistance 00A1
Head 03 Resistance 00BA
also , NRG list inquiry returned with
F3 T>V40
V40
Nonresident GList 1 entries returned
Total entries available: 1
PBA Len Flags Phy Cyl Hd PhySctr SFI
4E9B945 691C 0 29F1 0 0 D97C2
PostPosted: September 19th, 2014, 10:12
Have you tried regenerate translator? (m0,2,2,0,0,0,0,22)
PostPosted: September 19th, 2014, 10:29
shouldnt the translator regeneration take into consideration the NRG list ? like this command
m0,6,3,,,,,22
thanks for the advise
PostPosted: September 20th, 2014, 0:36
problem solved , thanks
Users browsing this forum: Google [Bot] and 57 guests
