 Post subject: WD10TMVW-11ZSMS1
PostPosted: September 25th, 2014, 3:31
kindly suggest a compatible SATA PCB for WD10TMVW-11ZSMS1 USB3 HDD? ORIGINAL pcb no is 2060 771737 000!!
SAFWAN
 Post subject: Re: WD10TMVW-11ZSMS1
PostPosted: September 25th, 2014, 4:36
How about a 2060-771692?
Both boards have the same MCU (88i9146-TFJ2) and motor controller (SH6601AF).
http://ep.yimg.com/ay/yhst-144375849714 ... 1692-3.gif
http://ep.yimg.com/ay/yhst-144375849714 ... v-p1-9.gif
PostPosted: September 25th, 2014, 5:05
do you tried it before?similar to your suggested pcb i have 2060 771820 000 from WD7500-24HXZT3 MODEL..But it not work.
PostPosted: September 25th, 2014, 5:11
I'm not a data recovery professional, but matching the MCU and motor controller seems like the obvious thing to do.
The 771820 PCB appears to use a different motor combo chip (WD Nautilus).
http://ep.yimg.com/ay/yhst-144375849714 ... 2601-1.gif
There was a thread in this forum that listed several SATA matches for USB PCBs.
PostPosted: September 25th, 2014, 5:31
your right..motor controller is not same also.thanks for your support.
Users browsing this forum: Google [Bot] and 54 guests
