ROM request WD 2TB 2.5
October 2nd, 2014, 11:28
hi guys,
somebody have got this rom from this new model of WD ?
Shrek LT 2.5
MOD: WD20NMVW-11AV3S2
Consolidated ROM version................ : 0001001C
ROM generation.......................... : 01.1CG
Re: ROM request WD 2TB 2.5
October 3rd, 2014, 3:47
ROM + 11.rpm
mikippp
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 8
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1480
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 01.1CG
>ROM generation.......................... : 01.1DG
>Link table version...................... : NA.28.
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Flash ROM dir reading (Ext)............. : Ok (Active)
>Modules directory address............... : 318 339
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 8
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3,4,5,6,7
>ROM Firmware version.................... : 0001001C
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
ROM.zip
(693.61 KiB) Downloaded 382 times
October 3rd, 2014, 13:08
thank you so much mikippp.
By the way there is at the moment some issues on this family (hot swap doesn't allow to read modules for example) but is under investigation from ace support.
So at the moment if you miss the rom and u got a donor rom, it does not work even if is the same version exact.
as far as i researched, u need also module 4F to be able to restore the drive when rom is lost.
