 Post subject: RAID 5 (3 HDDS) 2 HDDS GOOD
PostPosted: October 4th, 2014, 15:02
Hello to all!
Sorry!
I can not see the data on that partition ...
Please look jpg!
Thanks all helps!
:mrgreen:
Нет ничего невозможного
 Post subject: Re: RAID 5 (3 HDDS) 2 HDDS GOOD
PostPosted: October 4th, 2014, 16:20
Try a program like UFSExplorer that recognizes XFS.
PostPosted: October 4th, 2014, 16:33
the information that I have used the VMWARE
PostPosted: October 4th, 2014, 17:01
http://www.ufsexplorer.com/download_pro.php
The software allows to open disk images and virtual disks produced by virtual machines of the leading virtualization software vendors (including VMware Player, VMware Workstation, VMware ESX Server, VMware Fusion, Microsoft Virtual PC, Microsoft Hyper-V, Parallels Desktop etc.). The software operates virtual disks and disk image files exactly in a way as if they were physical disks and allows to access or recover lost data from disk images and virtual disks.
 Post subject: RAID 5 VMware recovery
PostPosted: October 4th, 2014, 17:21
Your description is rather scarce (what was the config according to the client, what happened, etc.) and I rarely use R-Studio, so would prefer not to guess blindly for now.
Reassemble the array in UFS Explorer and show what you'll get with it.
Should you decide you need an assistance, we'll be glad to help remotely. We get VMware recoveries quite frequently and can help even with unobvious things, like manual reassembly of virtual machines.
PostPosted: October 5th, 2014, 10:03
Hello!
is look part 3.jpg is stripe size 128kb no data is partition...
is part 2.jpg is stripe size 64Kb
PostPosted: October 6th, 2014, 5:45
Matter not in stripe size which you can change and try, change and try.
Matter is in layout . Datastore1, datastore2 labeling of volumes by default , uses mostly in P800 and newer server models , there is not regular Left Synchr mode.
Angel Data Recovery
PostPosted: October 7th, 2014, 8:15
ok thanks all infos!
Solved!
100% data recovery!
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
PostPosted: October 7th, 2014, 8:25
Solved!
100% data recovery!
Care to share the final configuration?
Users browsing this forum: No registered users and 68 guests
