 Post subject: Seagate ST9250410AS 7200.4 FW PROBLEM
PostPosted: October 23rd, 2014, 3:47
Hi guys,
I have this drive ST9250410AS that have the heads damaged. I swap the heads for a new ones and when i connected in PC3K the drive starts knocking. I change the heads map in the ROM for 1,1 and have the same result. When i change to 0,0 he became ready and have access to the FW. When i start to save the loader it start to give errors and lost stability. I Turn on/off and the drive now doesn't became ready and can't read anything. I saw the donor heads in microscope and they are clean.. i saw the log in the terminal and i got this message:
Rst 0x10M
LED:000000CD FAddr:00260AB7
So i think the drive has generated a FW problem.
Does any one saw this before? and know how to fix it?
Thanks for your time.
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
 Post subject: Re: Seagate ST9250410AS 7200.4 FW PROBLEM
PostPosted: October 23rd, 2014, 11:05
infofaster wrote:
I saw the donor heads...and they are clean..
What about patient's?
PostPosted: October 23rd, 2014, 11:13
The patient's heads are clean to.
PostPosted: October 23rd, 2014, 14:14
Have tried the heads back in donor drive?
http://www.rescue-it.se
PostPosted: October 28th, 2014, 12:02
Yes i put the heads again in the donor drive and they are reading well.
So any idea what is the problem?
PostPosted: October 28th, 2014, 14:46
media degradation in my opinion - soon to be media damage
PostPosted: October 28th, 2014, 18:38
+1
Users browsing this forum: Majestic-12 [Bot] and 58 guests
